Engine takes longer to start
R129 W163
Model you own: R129
Post by R129 W163 » Wed 02 Nov, 2016 3:27 pm
W163 99. ML 430 is cranking will not start takes good 10 sec. wants starts runs all day,
Leave it for 1hr same problem , but i you start within 20 sec, everything OK ?
New v Fuel Filter & Cranking sensors fitted.
Any help be great
Thanks Wally :dontknow:
mattml430b
Model you own: w163
Re: Engine takes longer to start
Post by mattml430b » Wed 02 Nov, 2016 3:33 pm
Definitely sounds like fuel delivery problem. See if you can get a fuel pressure gauge and test it.
Engine running it should be at 55 psi, and engine off after 30 mins should sit at 36 psi.
Your pump might be on its way out or the fuel pressure regulator in your new filter is faulty.
R129 W163
Model you own: R129
Post by R129 W163 » Thu 03 Nov, 2016 10:35 am
mattml430b wrote:Definitely sounds like fuel delivery problem. See if you can get a fuel pressure gauge and test it.
Thanks for the info , great I will check it out,
Looks like I need a new filter 1st , :love4:
