Command NTG 2.5 Headunit
Drummo
Model you own: w164
Post by Drummo » Tue 18 Oct, 2016 2:39 am
Hi there,
Can anyone please tell me what the SD Card slot above the display screen is for?
mattml430b
Model you own: w163
Re: Command NTG 2.5 Headunit
Post by mattml430b » Tue 18 Oct, 2016 8:53 am
Most likely be for navigation upgrades or music. At a guess.
Drummo
Model you own: w164
Post by Drummo » Mon 24 Oct, 2016 2:56 am
Apparently the GPS upgrades re done via a DVD not a SD card.
Post by T-Modell » Mon 24 Oct, 2016 5:04 pm
Well,
if you put a SD-card with music in, you can select it via "disc" ...
Drummo
Model you own: w164
Post by Drummo » Wed 02 Nov, 2016 10:10 pm
Is it possible to play music from an iPhone through the stereo using the cable via the USB connection in the glovebox through the 'Aux' option?
