Need some idea of what is broken
Post by 420 SE » Thu 06 Oct, 2016 4:44 pm
Got a very panicked call from my wife yesterday, while I was in Dubai and completely unable to help.
The ML 500 threw 'every light on the dashboard' said 'drive to workshop' 'do not change gear' and she was unable to put it into reverse.
It was also alarming which continued after the car was turned off.
A couple of hours later she was able to start and drive the car, including into reverse, without any warning lights or alarms.
Before I send it off to MB for their expensive recommendations to replace everything - what may be the likely diagnosis?
420 SE - 1988 (Lucy) - de-registered and likely to head off to the graveyard very soon...
ML 400 - 2015 (the Wife's Doha desert Duchess)
mattml430b
Model you own: w163
Re: Need some idea of what is broken
Post by mattml430b » Thu 06 Oct, 2016 5:47 pm
There is a plug on the gear box on the left hand side that will cause those symptoms. It may of come lose somehow. Check that first.
ChristoC
Post by ChristoC » Thu 06 Oct, 2016 8:16 pm
Time for your wife to get down & dirty and check that plug!
mattml430b
Model you own: w163
Post by mattml430b » Thu 06 Oct, 2016 8:30 pm
420 SE wrote:Got a very panicked call from my wife yesterday, while I was in Dubai and completely unable to help.
This is the plug. It may have oil or water in it for some reason causing the intermittent problem.
Post by 420 SE » Thu 06 Oct, 2016 10:31 pm
Thank you - will check it out.
Post by T-Modell » Fri 07 Oct, 2016 1:55 am
ChristoC wrote:Time for your wife to get down & dirty and check that plug!
The pictures you put in my head .... :laughing6:
