rear S A M unit help
ducko
Model you own: w164
Post by ducko » Wed 23 Sep, 2015 11:57 am
Gday...My 06 ML has sprung a leak near the right tail light and damaged my S A M unit.....
I have had no trouble finding other S A M units for the W164 from all over the world but none with the same numbers on them as mine!!
will these other units work in my car??
I am aware that it has to go into MB to get recoded or something..
frendomech1
Re: rear S A M unit help
Post by frendomech1 » Mon 28 Sep, 2015 9:10 pm
Hi, they generally will work but once permantly fitted to the vehicle it will need to be coded to the vehicle, I have put spare ones in just to test old ones have failed but new ones must always be coded to the vehicle.
ducko
Model you own: w164
Post by ducko » Wed 30 Sep, 2015 7:18 am
Cheers for that...So if I buy a used one it should be plug and play??
I want to get one before the week end and looks like 2nd hand is the only way that's going to happen!
ducko
Model you own: w164
Post by ducko » Tue 20 Oct, 2015 8:38 pm
so I got my new SAM today and it was plug and play!! found out where the water leak was coming from too and it isn't the tail light!!
