aerial on my w124
hyjinx
aerial on my w124
Post by hyjinx » Thu 16 Aug, 2018 11:54 am
Hi just did a search and didnt find the answer.
Do the aerials on w124 sedans retract all the way or do they stick out about 200mm when stereo isnt on?
89 - 230E "Meghan Mercle"
71 - 280SE "Browntown" R.I.P.
71 - 280SE 3.5 "Seedyz" R.I.P.
Re: aerial on my w124
Post by John Green » Thu 16 Aug, 2018 12:42 pm
Retract all the way.
Post by T-Modell » Thu 16 Aug, 2018 3:58 pm
When they're even older and not taken care off, they don't retract at all ... and they should have a motor :laughing6:
Try putting some oil on it; if that doesn't work, you have to dismantle it ...
hyjinx
Post by hyjinx » Thu 16 Aug, 2018 4:49 pm
Yeah ive had the electric aerials on other cars that do none of the up or the downs lol.
This one though does work and was pretty well maintained the aerial was the "sticking point" as it was remaining 2 sections up i then added some lubrication and now she is like the picture.
Oh and thanks john i missed your reply.
dhaigh
Post by dhaigh » Mon 20 Aug, 2018 2:55 pm
Retract all the way. I would use PTFE dry lubricant rather than oil, as oil will attract dirt/grit which will stick to the mechanism.
Try using a bit of (hand) pressure on the tip as it retracts, and you may find it goes all the way in.
1988 300CE Coupe
Departed:
1989 300E
1990 MX5
1966 Ford Fairmont
1954 Healey BN1
1972 E-Type V12
etc
hyjinx
Post by hyjinx » Mon 20 Aug, 2018 4:06 pm
Alittle pressure alittle graphite powder and it now sticks sometimes but its a start :) thanks for the help. :wav:
Now i need the rubber boot around it this ones perished unfortunately.
xbberni
Post by xbberni » Sat 01 Dec, 2018 11:55 pm
Nearly 4 months ago so did you get the boot for it? heers
dhaigh
Post by dhaigh » Wed 12 Dec, 2018 5:57 pm
If you need the rubber boot for the base of the aerial, call or TXT me on 0412 550 020
1988 300CE Coupe
Departed:
1989 300E
1990 MX5
1966 Ford Fairmont
1954 Healey BN1
1972 E-Type V12
etc
