Part numbers
Daniel33
Part numbers
Post by Daniel33 » Thu 14 Jun, 2018 5:33 pm
Hi everyone.
Having recently purchased a W124 300D Sedan with a blown motor I am in need of some part numbers to order some replacement bits. Is there a place in the forum where part numbers are listed or is there a library? I need a cylinder liner and possibly some pistons as well as rings and bearings. Haven't yet stripped the head down to check the valves. Can anyone help me out? I can order the parts from a local car stealership but I need the OEM part numbers for their communication with Mercedes Benz. Thanks in advance.
Also been looking up on wickipedia trying to find out some more info. Seems it has a 603 model engine with the #16 mold head. It was running on bio-diesel and burnt through the lining on number 4 cylinder. Any suggestions as to perhaps why would be appreciated as the plan is to continue running it on chip oil.
Re: Part numbers
Post by John Green » Fri 15 Jun, 2018 10:16 pm
Umm, I would suggest you try a differant stealership if they have been asking you to look up your own part numbers? That's there job, or at least it was mine when I was in the parts industry.
Daniel33
Re: Part numbers
Post by Daniel33 » Sat 16 Jun, 2018 12:57 pm
Yeh, they normally would, except I am working there in the PD department and if I want to get the parts I need at wholesale price, I need to supply part numbers so they don't have to spend much time on the order.
dhaigh
Re: Part numbers
Post by dhaigh » Tue 19 Jun, 2018 8:34 pm
You may find this website has the Part Numbers you want.
http://freescruz.com/.priv/W124/Main.html
Good luck
1988 300CE Coupe
Departed:
1989 300E
1990 MX5
1966 Ford Fairmont
1954 Healey BN1
1972 E-Type V12
etc
nitchioo
Region: Australian outlaying islands-Territories
Re: Part numbers
Post by nitchioo » Fri 13 Jul, 2018 4:22 pm
I've found this website pretty useful.
Just put in your VIN & choose lingo at top.
http://mb-teilekatalog.info/
regards
210065 E320 5sp. Auto Sedan (green-black) Avant-garde
124088 300TE_2.8 4sp. Auto Estate (blue-black) Classic
124023 230E 4sp. Auto Sedan (silver-gold) Classic
