Not the neutral safety switch!
Charlie Buckett
Post by Charlie Buckett » Fri 01 Sep, 2017 6:39 pm
So I have been starting my car in neutral for months (actually had to align gearstick just above neutral).
Then it finally didn't start one day, so I figured neutral safety had finally packed it in.
So I bumped the starter and got her home.
Ordered new NSS (made in Germany - Trucktec Automotive?).
I aligned it with the allen key guide.
Car still did not start.
I aligned it evey other way. Never started, But the reverse lights always worked even if misaligned!
The headlights dont dim when I attempt to crank
There is no noise from starter
Ignition isn't wobbly.
I know nothing about electrics (mechanics more my thing) barely know how to use a multi meter.
Any help? Thanks
MMWA
450 SEL 6.9
Re: Not the neutral safety switch!
Post by MMWA » Fri 01 Sep, 2017 8:53 pm
are you sure its not your shifter handle linkage bushings disintegrated ?
is the knob floppy or stiff in its clicking into positions? If it is flopping around your bushings are flogged out / gone.
MMWA
Post by Ivanerrol » Fri 01 Sep, 2017 10:45 pm
This is what MMWA is talking about.
There are two.
Charlie Buckett
Post by Charlie Buckett » Sat 02 Sep, 2017 10:27 am
Yeah thanks guys, I replaced both those bushings not long back.
I suppose it must be solenoid or ignition but I dont know how to test.
If it was the solenoid would I still be able to bump the starter? (I'm doing that off some plug above the battery, I don't even know what it is, electrics confuse my noggin).
Confusing the reverse lights come on even when misaligned, but I have it aligned perfectly with the allen key guide hole.
I'm starting to think I got a dodgy NSS, I bought it for $74, but it's made in Germany so I thought it would be good (Trucktec).
Post by Ivanerrol » Sat 02 Sep, 2017 11:22 pm
Trucktec - dare I say it ....possibly less than reliable.
Some of their parts are made in ???????? butt boxed in Germany
Charlie Buckett
Post by Charlie Buckett » Sun 03 Sep, 2017 1:34 pm
Darn, but could it possibly arrive not working, as opposed to not lasting long?
I can't think of any way to determine if the new switch is a dud (except buying a more expensive one).
Post by Tony From West Oz » Sun 03 Sep, 2017 1:46 pm
Charlie, To test the NSS.
Tools:
Multimeter (with buzzer on ohms range preferably) - A test lamp and suitable connectors would suffice if you do not have a Multimeter.
Method:
Disconnect the NSS wiring connector. Identify the starter lockout contacts of the NSS and have an accomplice move the gear selector between P, R, N and D in turn to see if the contacts close. Repeat for Reverse light contacts.
Alternatively, remove it from the vehicle and test it on the bench.
Charlie Buckett
Post by Charlie Buckett » Sun 03 Sep, 2017 2:55 pm
Thanks heaps I 'll test that a.s.a.p
Charlie Buckett
Post by Charlie Buckett » Sun 03 Sep, 2017 3:11 pm
I tested the old one that was playing up.. and on the reverse light contacts I get 1 beep as I move the selector through the range.
On the other set of contact I get 2 beeps as I move the selector through the range. (not sure if there should be 4 beeps?)
I will test the new one which is on the car tomorrow.
I really appreciate this info. Thanks.
Post by Tony From West Oz » Sun 03 Sep, 2017 8:57 pm
The old one sounds like it is working correctly. The Reverse contacts beep should not occur in the same place as the starting contacts beep, but should be between the 2 starting contact beeps. Is that beepingly clear? ;)
