Fuel pump relay
Graemem
Fuel pump relay
Post by Graemem » Thu 31 Aug, 2017 8:20 pm
New to the forum and need help. My 86 W124 230e has trouble starting without a spray from start ya bastrd into the air box. From there the revs cycle from 500 to 1500. I have checked the coolant sensor, the output to the cold start valve and replaced the ovr. Fuel pump and accumulator have previously been changed out. The previous owner has done some weird fix to a relay next to the ovr.....is this the fuel pump relay?
Is there anything else i should be looking at?
Christo C
Re: Fuel pump relay
Post by Christo C » Fri 01 Sep, 2017 10:16 am
Yes that is the Fuel Pump Relay.
~Christo
Graemem
Re: Fuel pump relay
Post by Graemem » Sat 02 Sep, 2017 4:49 pm
Thanks Christo.
