W124 1995 E220 CD Stacker
Budgie
Post by Budgie » Sun 01 Jan, 2017 3:53 pm
Hi All,
Just purchased a 95 E220 and looking for a CD stacker to install (unless it's there and I can't find it) anyone have one they'd like to part with or can recommend an after market one to buy that will be plug and play?
vincent
Re: W124 1995 E220 CD Stacker
Post by vincent » Sat 10 Jun, 2017 2:22 am
im looking into replacing the stereo on a W124 1995 E220 i just brought, i probably wont need the cd stacker etc, i will post back here once i have figured out replacement for the stock head unit that came with the car, i will most likely be putting in a PIONEER DEH-X3950BT
bberni
Post by bberni » Mon 14 May, 2018 10:16 pm
I have a 1993 124 with a 10 stacker
which I hardly use and now am happy to pass it on esp. as I am also planning to part the car out due to the fact that I am on pension and not travelling that much.
Car has done 302,000 kms and is a great ride. BUT I have a 95 which has just clicked over 200,000 km. !! Leather and air (which works). It's my third 124..
wow cars! easy DYI maintenance with the help of John, our sponsor and team (plus a bit of u-tube) ! and club members here, with BIG thanks..
Please message me if interested in the C-D unit or more
regards
B.
I can translate to /from German for you. von DeutSchland!
Post by Ivanerrol » Mon 14 May, 2018 10:30 pm
Do you actually have the original audio unit in the car?
M.B.'s of that era were supplied to Australia with no head unit. M.B. Oz installed locally sourced Eurovox which catered for odd Oz FM frequencies.
If you still have the original Eurovox. This was the stacker I had in my W202's - in the boot. : http://www.electronicrepairs.com.au/ind ... rious-10cd
bberni
Post by bberni » Tue 15 May, 2018 9:04 am
on just a glance, I do.
Have had the car 9 years - only one PO
will check all stats if unit is still wanted and have the Eurovox books as well
works gr8
thanks for the pic.
Post by Ivanerrol » Tue 15 May, 2018 5:45 pm
Eurovox being Oz sourced didnt have anything to do with international conventions :whistle:
As such the head unit has a ‘special’ connector for the cable between it and the CD stacker.
My advice is go and get a aftermarket modern unit with all the bells and whistles.
Keep the Eurovox and pyt it back in when you sell the car.
My W204 unit has a hard drive you can down load music files too - as well as a SD card spot, USB and an old aux port.
Post by Ivanerrol » Tue 15 May, 2018 5:50 pm
F.W.I.W.
Those last series W124 E220’s ate really good cars.
The only real issue to worry about is the engine wiring harness.
bberni
Post by bberni » Tue 15 May, 2018 9:02 pm
replaced them on both cars myself already Ivan and ran like new since! sweet as
B
Post by Ivanerrol » Tue 15 May, 2018 9:51 pm
B
:thumbsup:
