w220 s320 - no start
kbro3
Model you own: w210
Post by kbro3 » Fri 13 Apr, 2018 4:44 pm
Hi guys!
Wondering if anyone can tell me the common causes of a no-start, no turnover condition on a 2001 w220 s320?
I'm looking for w220 specific issues here - so for example, flat battery is not unique to a w220.
Thanks!
Re: w220 s320 - no start
Post by Ivanerrol » Fri 13 Apr, 2018 5:04 pm
More info needed.
Do the cluster lamps come up when the key is inserted?
Can you lock and unlock the car with the key OK?
Jazzville
Post by Jazzville » Sun 10 Feb, 2019 10:35 am
Hi kbro,
I know this is a very late reply and you have probably solved the problem by now. However, this may be food for other as well. When I first purchased my S320 second hand, I had issues with the car simply shutting down. The engine would turn okay but it simply wouldn't start. It turned out to be a simple sensor which can be bought on line - just need to look around. Once that sensor was changed, I never had a problem with it again. The car runs beautifully. Hope this helps someone.
Clive
