W211 E200K rough idle when cold
Alex
Post by Alex » Mon 03 Sep, 2018 10:10 am
I have recently replaced my 1.8 litre motor (failure after 380,000km) and the new rebuilt motor runs very well but does not idle smoothly when cold.
My mechanic has not been able to solve this problem despite a number of attempts.
A summary of observations is as follows:
1. On cold mornings, the engine starts and idles at around 1200rpm in PARK. It is a smooth fast idle.
2. When placed in DRIVE, the revs drop to around 700-800 and it idles roughly and shakes.
3. Once I accelerate, the revs increase and power is very smooth.
4. Upon the engine reaching normal operating temperature, it settles to around 600 RPM at idle and smooth.
I would appreciate your advice on how to increase the idle speed when in DRIVE as part of the cold start. The original motor had no idle problems whatsoever and idled smoothly on cold starts.
Sincerely
Alex
Re: W211 E200K rough idle when cold
Post by Ivanerrol » Mon 03 Sep, 2018 9:23 pm
380,000K's out of a modern turboed 4 cylinder :wave:
All engine controls on those engines are computerized so no real manual changing of settings such as idle speeds.
It will probably either be a sensor or some vacuum leak somewhere. How is the MAF?
Rebuilt engine - M211 or M271?
Alex
Post by Alex » Tue 04 Sep, 2018 12:14 pm
Thanks for your response Ivanerrol.
The rebuild is an M271. I was expecting a little more than 380,000 km but perhaps this is unrealistic for a supercharged 4 cylinder.
My mechanic also thought it was a vacuum leak and has checked and replaced a number of vacuum related components without success.
He also cleaned the MAF housing and sensor.
Alex
