Hello all
Today I went to adjust my drivers seat back, using the switch on the door.
I pushed the switch back to move the seat back, BUT, the seat went forward!!
I then pushed the switch to move the seat forward, and that worked normally.
Lucky the memory switches worked and it went back.
Any suggestions?
DAZ
Seat won’t go back
- S Class
- Model you own: w116
- Region: New South Wales
Re: Seat won’t go back
Dead switch, as you have already worked out the motors and cables work fine. The older switch you could pull them apart and clean up the contacts, I doubt you could do this with these ones as they also have the controller model in them.
- S Class
Thanks John
Do you have any w210 parts, including one of these switches amounts your spare parts?
Darren
Darren
