Fuel Pump Voltage
BlueG
Fuel Pump Voltage
Post by BlueG » Thu 26 Apr, 2018 12:46 pm
Hope that someone can shed some light on a problem I am having with a 2005 W211 E280 petrol.
Car intermittently turns over but won’t start. Traced the problem to the fuel pump as when I thump the underside of the tank the pump starts. However before I replace the pump I checked the supply voltage and it is only 10.5 VDC at the sender unit connector under the seat. Could this be a problem with the SAM unit and not the pump.
