W210 E280 1999 Hard Starting
dwn06
Model you own: w210
Post by dwn06 » Wed 26 Apr, 2017 11:04 am
As new MB owner,
i have now owned on E280 for only a month, but have found when i have driven the car and parked it it has taken up to five starts to get the car to run.
could it be a fuel pump or a pressure regulator problem?
any advice ?
Re: W210 E280 1999 Hard Starting
Post by Ivanerrol » Thu 27 Apr, 2017 7:34 pm
First. Make sure your battery is up to scratch.
You need a DIN 88 or DIN 95 or DIN 100 battery. it's located under the back seat - drivers side.
The battery voltage must be more than 12.4 volts before you start to crank.
You can go to a battery store to get the battery professionally checked out.
If you are in Melbourne, there is man in Box Hill who sells very good appropriate batteries for good prices.
If your battery is good, then you need a man with a code reader.
dwn06
Model you own: w210
Post by dwn06 » Thu 18 May, 2017 7:28 pm
thanks Ivanerrol,
but after some testing and getting the to fault again found that the cam sensor had a intermittent fault which i replaced today. I will see how it goes this time.
thanks
Guy
dwn06
Model you own: w210
Post by dwn06 » Sat 22 Jul, 2017 8:19 am
Have started getting the issue back again.
does anyone know how to test Bosch Ignition Coil (0 221 503 035).
have looked starter motor it cranks the motor just seems not want to fire?
any other place i should be looking?
Guy
Post by Ivanerrol » Sat 22 Jul, 2017 6:40 pm
You have 12 spark plugs and six ignition coil packs. Hard to find which coil pack is crook.
Have you had the codes read?
Is this problem associated with the cold weather?
dwn06
Model you own: w210
Post by dwn06 » Mon 24 Jul, 2017 7:51 pm
yes i have 12 spark plugs and 6 coil packs.
no i do not a have a code reader yet.
it happens at odd times, i have have tried to keep a record of when it happens its at odd times and weather conditions.
dwn06
Model you own: w210
Post by dwn06 » Thu 04 Jan, 2018 5:58 pm
After much fault finding looks like it was purge valve (part: 0004708593) MB dealer wanted 280.00, got from the US for 100.00
Post by Christo C » Thu 04 Jan, 2018 6:50 pm
Post by Ivanerrol » Thu 04 Jan, 2018 9:00 pm
A lesson for all.
Never overfill the petrol tank. There's a risk of flooding the Charcoal canister and damage the purge valve.
If the carbon purge canister gets damaged - they are hundreds of dollars for replacements.
