Hi R129 Lovers.
Got one best Sports ihave ever had. 97/98" SL320 (104)
DID SOME WORK ON IT LEARNED A LOT.
The only problem i have had is with the roof
Module. got fixed. Bad spot for mounting!!
no rubber Support!!
& Battery not having aVent to the outside. :D
In the SA Merc Club we have now 6 SL R 129.
& Growing.
Cheers Wally
SL R129
- Dernburg Wagon
- Model you own: R129
- OzBenzHead
- 300 SLR
- Model you own: w126
- Region: New South Wales
Re: SL R129
G'day, Wally. :D
Where are you?
When you mention the "SA Merc Club" are you referring to South Australia or South Africa?
Where are you?
OzBenzHead
Currently:
1983 C126 500 SEC – Bruno
2003 BA Falcon ute 4.0L Barra 182 – Henry
Formerly:
1955 W180 220a – Ponty
1964 W112 300 SE/C – Béla
1965 W111 220 S – Hektor the Heckflosse
1970 W108 280 SE – my first Benz – Karl
1973 W116 280 SE Crayford Estate – der Rolfwagen
1975 W116 450 SE – Goldy Horn a.k.a. Thirsty Merc
1980 W116 280 SE – Boris
1989 W124 300 E – Hester
1992 W201 180 E – Babe I
1992 W201 190 E 2.0 – Babe II
+ numerous W108/116 rolling spares
Prior to my M-B epiphany:
53 cars including many British oil-leakers (e.g. 14 P4 / P5 Rovers!), frequently cursed by Lucas the Prince of Darkness. Learnt to drive grey Fergie tractor and '27 Nash paddock-basher ute aged 8. First car owned (age 13): 1953 Fiat 500.
Currently:
Formerly:
- Dernburg Wagon
Re: SL R129
Hi OZBENZ>
SA is South Australia we are in the Adelaide Hills.
Cheers Wally :D
Cheers Wally :D
- Alanbutler
Re: SL R129
Hi Wally,
I have just bought a 1995 SL320 (hard top / soft top roadster) - originally sold in HK. This is my first Merc and I think it is a R129. Since driving it home it will not respond to key fob central locking and is completely shut down. REplaced car battery and those in push button. The central locking responder appears to be part of the rear view mirror with red and green lights to indicate on / off - not working at present. Tried syncing the handset as per book with no luck. Looks wonderful but I want to drive it Any hints? AB in Sydney
