Leaking oil and distributor wire
Martyn 280CE
Post by Martyn 280CE » Sat 29 Sep, 2018 4:33 pm
Hi I have a couple of issues:
WDB123053.2A.218049
She was missing running rough very slightly at tick over I noticed the green lead had partly crumbled at the Distributor.
I Ordered and waited for the wrong part accidentally 000-159-82-18
Its slightly too big I could perhaps get its in and make but its a brand new lead and she is great original condition so I should do something proper.
Anyone advise on how they would do it.
I checked the Forums and found there are two possibilities
But which do I need 000-159-61—18 OR 000.159-85-18
Can anyone advise me.
My VIN WDB123053.2A.2180491984 W123 280CE
At the same time I also bought a new bonnet safety plug and haven’t tried putting that on.
Also i put her in my storage area for the last four months - whilst moving house recently.
I have noticed a bad leak has happened I have taken a couple of pictures. I honestly have never had a leak ever except for the Old AC Compressor one time.
Can anyone recognise what fluid it MIGHT be, its actually very slippy AND I need to clean its up before crawling on the floor..!!
Thanks again for anyones help
Martyn
Martyn.
1984 280 CE
Sydney, Northern Beaches
tsharkey
Re: Leaking oil and distributor wire
Post by tsharkey » Sat 29 Sep, 2018 5:23 pm
If the fluid is redish in colour, it will be the transmission. I had a wagon sit around for a few months and when I shifted it, I got a leak at the rear. Rear transmission seal fixed it.
Martyn 280CE
Post by Martyn 280CE » Sun 30 Sep, 2018 11:40 am
Sorry - I thought I posted this reply last night.
Thanks so much for the quick reply Tsharkey,
Did you see the pictures I do remember it being Its reddish in colour I will check again tomorrow.
I had a transmission kit filter installed around two years ago - Is that what you think it might be.?
Your wagon was leaking at the rear pretty sure my coupe is at front to middle - Does that make sense are there two transmission seals one front an one rear..?
I am just remembering,mbering the last time I took it for rego check they said there was a small leak on the Transmission seal.
Thanks Martyn
Martyn.
1984 280 CE
tsharkey
Post by tsharkey » Sun 30 Sep, 2018 1:24 pm
Sorry - I meant rear of engine - trans assembly which told me it wasn't the power steering.
Looks like you have found your culprit.
Martyn 280CE
Post by Martyn 280CE » Wed 28 Nov, 2018 7:30 pm
Hi I have replied to this instead of posting new.
I have put it back together the distributor cap I struggled with putting it back on
So I had to remove all the leads in my effort and had no pen handy.
And googled the firing order and tried that - 135642
Seriously she always starts first turn.
She wouldn’t start I didn’t try for long she was kind of backfiring aswell
How do I know which is the first on the distributor
Martyn
Martyn.
1984 280 CE
Post by Chai » Wed 28 Nov, 2018 10:34 pm
Any numbers on top of the distributor cap, near where each spark plug leads connect to the cap?
Martyn 280CE
Post by Martyn 280CE » Wed 28 Nov, 2018 11:22 pm
Hi I don’t recall any visible numbers I will check in the morning.!
Martyn.
1984 280 CE
Henry Schuman
Post by Henry Schuman » Thu 29 Nov, 2018 8:54 am
ZUNDFOLGE is 153624 You have the Firing (ZUNDFOLGE) order wrong. BUT you have to know where #1 is on distributor cap and which way the rotor turns
Post back for more info if you need to
When any car sits long it can seep oils ,start it up and replenish any low fluids and then keep an eye on it .
Pete49
Post by Pete49 » Thu 29 Nov, 2018 2:22 pm
turn crankshaft to number 1 tdc on the timing marks and lift dizzy cap. place number 1 lead in the cap where the rotor sits as it would be number 1 then place the rest of the leads in the order Henry S mentioned in a clockwise direction.
1978 W123 300D Maple Yellow
1983 W123 280TE Champagne
1975 W116 450SEL Silver blue
Martyn 280CE
Post by Martyn 280CE » Thu 29 Nov, 2018 9:45 pm
Thanks so Much Henry and Chai,
Very relevant and helpful..!!
I actually had the firing order correct but had the wrong numbers on the leads.
I am so happy I even had her running this afternoon. She started first time.
I am going to take her to the Garage for the transmission oil seals.
And look after her as she deserves.
Thanks again both
Martyn
Martyn.
1984 280 CE
Martyn 280CE
Post by Martyn 280CE » Thu 29 Nov, 2018 9:51 pm
Thanks again both
Martyn
Martyn.
1984 280 CE
Martyn 280CE
Post by Martyn 280CE » Thu 29 Nov, 2018 9:57 pm
Also you weee right the cylinder numbers are stamped on the cap by each contact.
Thanks to you I knew I had done it correct and that she would start and she did.., :whip:
Martyn.
1984 280 CE
Martyn 280CE
Post by Martyn 280CE » Thu 29 Nov, 2018 10:07 pm
Sorry I only just saw Pete’s reply too
So Thanks Chai, Henry and Pete.
Martyn.
1984 280 CE
