Hi, so, the guys at the stealership didn't know which way the heat shields are to be placed into the prechamber for the injector to sit on top of.
this is for om617a
does anyone here know ? I've had conflicting things turn up with mr google :/
Heat shields
- Große
- Pagoda
- Region: Queensland
Re: Heat shields
Here is a link that shows you the way they go very heplful info forum member Julian shared with me after purchasing a set of monark nozzels from him.
http://www.peachparts.com/shopforum/die ... g-diy.html
1984 300D Auto Manila beige
1979 240D Manual Light ivory
1976 300D Auto Mimosa yellow
1978 300D Auto Sahara yellow
Re: Heat shields
mathuisella wrote: ↑Mon 17 Sep, 2018 3:53 pm Hi, so, the guys at the stealership didn't know which way the heat shields are to be placed into the prechamber for the injector to sit on top of.
The info on the Peach parts link is correct.
