300TD Vacuum configuration
Dweezil
Post by Dweezil » Thu 13 Sep, 2018 9:48 am
Hi Team,
Jurgen is a 1981 TD with a 722.118 trans. The notes that I took when I was disassembling got covered in oil, so I can't remember for the life of me where everything is supposed to reconnect. I've looked at online schematics, but there seem to be infinite variations between years, trans configurations, LHD/RHD etc, so if anyone can tell me which lines go into which bits it'd be hugely appreciated.
And yes, it looks like there's a split in that Y connector.
Dweezil
Dweezil
Re: 300TD Vacuum configuration
Post by Dweezil » Thu 13 Sep, 2018 9:51 am
tsharkey
Post by tsharkey » Thu 13 Sep, 2018 6:40 pm
1 - Black to transmission modulator
2 - Red stripe to 5 on IP (Left)
3 - Green stripe to Tee 6 plugged into IP (right)
4 - Brown - Fuel shutoff into cabin
5 - Red stripe to 2 on 3/2 Valve
6 - Green stripe to 3 on 2/3 valve
7 - Green stripe to Vacuum supply (check valves near brake booster)
8 - Black (air inlet) to inside of cabin.
