Shudder when accelerating after stopping
tsharkey
Post by tsharkey » Sun 18 Mar, 2018 9:25 am
Hi - The wagon with the reco transmission has a shudder when accelerating from standing. If you back off, it goes away. It is really only when you are under load and only until you hit about 20kms (then goes away). Feels like it is at the back of trans tho you can't feel it through the selector.
Rear trans mount ?
Flex plate ?
Both are old (well, I have owned the wagon for 12 years and never replaced them) ..... What do I look for when inspecting (which I will do later today).
Trans itself (back under warranty if thats the case)
Region: Western Australia
Re: Shudder when accelerating after stopping
Post by Tony From West Oz » Sun 18 Mar, 2018 7:15 pm
I would be going back to the transmission centre that did the reconditioning. Sounds like you have an issue with the 1st gear clutch pack slipping.
tsharkey
Post by tsharkey » Sun 18 Mar, 2018 10:55 pm
Thanks Tony - I looked underneath and both mount and flex looked A-OK. Will book it in.
Post by Mercmad » Sat 31 Mar, 2018 11:18 am
Flex plates get old with time, and hard. Any tiny cracks are the reason to change them because once they start cracking it's the end of them. Do both , one each end of the drive shaft and check the center bearing rubber too.
tsharkey
Post by tsharkey » Wed 09 May, 2018 9:29 pm
Thanks Ron - Exactly what was at fault, the centre bearing was completely worn out.
mathuisella
Post by mathuisella » Wed 16 May, 2018 10:42 am
This was the issue with my car as well. :)
