Losing vacuum as soon as engine stops ?
mathuisella
Post by mathuisella » Fri 24 Nov, 2017 3:14 pm
Hi everyone, well i'm sorting out the vacuum system and here's how it goes so far.
Engine on, all doors work as well as fuel cap and boot.
the moment i shut off the engine after parking, i lose all vacuum and the door won't lock, however if i wind the window down, step out of the car and lock the door with the drivers door button they all work perfectly, both to lock and unlock.
so, Engine on Vacuum all good
Engine off, no vacuum :/
any ideas ?
I've so far done 10 inches of mercury test on the tank in the boot, it holds pressure for minimum of 15 minutes.
I put vacuum pressure ( hand vacuum pump ) on the door lock and door unlock lines from the bonnet check valve and all seems okay, doors open and close.
tsharkey
Re: Losing vacuum as soon as engine stops ?
Post by tsharkey » Fri 24 Nov, 2017 3:48 pm
The check valve in the engine bay runs 1 line to the vacuum tank up rear and the other to the lock / unlock valve in your Drivers door. The Lock \ Unlock valve in the drivers door shifts the vacuum between lock / unlock (green / red stripes). The reservoir up rear has vacuum in it to allow multiple lock / unlock as you loose a little vacuum when you switch between the 2 modes.
With the engine off, no new vacuum is being supplied. You say the engine is off and there is no lock / unlock anymore.
Either the check valve is kaput (it is leaking the vacuum back into the main line and being vented else where) or the lock / unlock valve in your door is leaking.
However ... You say
Does that mean that when you are in the drivers seat and switch the engine off, you can not lock / unlock the doors anymore using the door button ? If so, the above applies.
If the door lock button works, but when you are outside the car, the key wont lock / unlock, then I suggest the Key mechanism is not linked to the door and your central locking is working A-OK.
mathuisella
Post by mathuisella » Fri 24 Nov, 2017 4:49 pm
However ... You say
sorry i should be more clear, everything works fine ( engine on ) whether i use the key from outside or i'm inside the car and use the drivers door button
engine off - no vacuum functions work.
Post by Bartman4800 » Fri 24 Nov, 2017 4:57 pm
Did you accidentally reverse a check valve? The one to the brake booster?
Easy to check, just suck on it...
tsharkey
Post by tsharkey » Fri 24 Nov, 2017 5:01 pm
The one in, 2 out Check Valve is not holding the vacuum - Your donor car has plenty.
mathuisella
Post by mathuisella » Fri 24 Nov, 2017 5:44 pm
Looked in the doner car :/ it doesn't have central locking :O
seems like it was bottom of the barrel spec :/ no bells or whistles. 4 speed manual 240d no central locking, wind up windows, no sunroof or anything.
but at least the engine is nice :) and the body is 100% rust free
any ways.
i disconnected everything and used some silicon vacuum line to directly connect only the front passenger door to the drivers door.
1. i ran the engine for 30 seconds.
2. turned engine off
3. sat in drivers seat
4. pressed button down as i watched the front passenger, it locked, then unlocked.... cycled 8 times ( 8 locks, 8 unlocks ).
So it seems my problem is either in another connection or actuator :/
but i have to go to work now for the night, so we'll see how we go tomorrow.
cheers for the help so far guys :)
mathuisella
Post by mathuisella » Thu 30 Nov, 2017 5:01 pm
Looks like my rubber Y adapters ( factory) have come loose over time.
I went to the usual auto places, their vacuum stuff is so expensive, I'm just going to make my own on my 3d printer.
Post by Tony From West Oz » Thu 30 Nov, 2017 10:36 pm
Why not use reticulation trickle tube barbed Tees and Crosses for your multi-way connections. Use bog standard vacuum hose to connect the crosses or tees to the rigid vacuum lines.
I did this and it works fine on my W123 300CD Turbodiesel.
mathuisella
Post by mathuisella » Sat 02 Dec, 2017 4:16 pm
That's pretty much what i'm doing, but the local places had nothing for me, wrong size or just too expensive.
Post by Tony From West Oz » Sat 02 Dec, 2017 4:32 pm
Have you got a big green shed near you? They usually have the barbed connectors and the trickle hose (right size, does not like the heat, but can be used to test the system) when you have it sorted, replace with vacuum hose. Have you tried ebay for the hose?
mathuisella
Post by mathuisella » Sat 02 Dec, 2017 4:37 pm
the original vacuum hose lines in my car is good with no leaks. I'm just using solicon vacuum line over these connectors and the original vacuum hardline in the car, works well :)
mathuisella
Post by mathuisella » Sat 02 Dec, 2017 11:58 pm
Locking side works fine, seems the open side has a leak further down the line so to speak :)
will move towards the rubbers on the actuator and test those tomorrow.
