Dash switch question
mathuisella
Post by mathuisella » Tue 07 Nov, 2017 11:47 am
Hi everyone, well i have switches on my dash, but there's one that doesn't seem to do anything...
2nd from the left, looks like a light switch, but a switch it and it does nothing :/ or that i've noticed...
the other light switch does the switch over the rear passenger seats.
Also any tips on how to remove the panel so i can follow the wiring behind it ?
Re: Dash switch question
Post by Tony From West Oz » Tue 07 Nov, 2017 10:49 pm
The left hand light switch has been put in by a previous owner. That location should be for change to the horn sound (Fanfare Horn switch) where fitted.
mathuisella
Post by mathuisella » Wed 08 Nov, 2017 8:16 pm
Thank you tony. I'll try the horn and see how it goes :)
is there a particular way to take this rectangular section of the dash out if i wanted to add something into the blank spot in the middle so it looks factory ? :)
Post by Tony From West Oz » Wed 08 Nov, 2017 11:53 pm
I doubt that switch is for a fanfare horn as it was not factory installed. When you find out how to remove the panel, then you can see what is wired to it.
