280CE EGR Valve Gasket?
nea100
Post by nea100 » Mon 30 Oct, 2017 3:02 pm
Out for a run yesterday and could hear a ticking noise on acceleration. Upon investigation found the EGR valve mounting on the exhaust had sprung a leak. I'm not sure on how the mount should be but it seems there are too many gaskets here, and they have blown out on one side.
Can anyone please help with this as I am thinking there maybe should only be the one gasket between the valve and the header? One of the bolts doesn't look too good either - could be broken - oh dear.....
Thanks,
Col.
1984 300D - Gold, Gold, Gold
1984 280CE - Silver Blue - Undergoing minor restoration
1970 Valiant VG VIP - White - Distant relative
Re: 280CE EGR Valve Gasket?
Post by Tony From West Oz » Mon 30 Oct, 2017 5:10 pm
Get a sheet of galvanised iron and 2 gaskets. Cut the galv to be slightly smaller than the gasket outline. drill / punch the 2 bolt holes but not the EGR path thru the gasket.
Reassemble with a gasket on each side of the galvanised steel with the EGR valve on the outside. Bolt it up tight.
See MB Spares for the gaskets and replacement studs too.
This should be an easy job. It may already have a blanking plate installed.
Lance
Post by Lance » Mon 30 Oct, 2017 5:29 pm
Looks like mine. But yours is not operational as one of the vacuum lines if disconnected. Tony, does your suggested modification improve performance?
Lance Smart
W114 280E 5 speed manual
W123 280E
Post by Tony From West Oz » Mon 30 Oct, 2017 5:57 pm
Yes, you no longer have a lot of exhaust gas coming into your inlet manifold and causing the engine to run rich (more Co2 and less O2 in the mixture) so fuel economy and/or performance is improved.
Emissions resulting are and increase of NOx due to higher combustion temperatures, but a significant decrease in CO2 due to improved combustion and better fuel economy.
Which is better? Well the scientists may have an answer, but I think lower CO2 is my preference.
nea100
Post by nea100 » Tue 31 Oct, 2017 4:05 pm
Thanks. Unfortunately one of the studs is broken off in the header, so I'll have to get the remains out of there first. No blanking plate though.
This car has had a few "'changes" made by the previous owner and the missing vacuum line is one of them, so I don't know exactly what is going on there as yet, still learning. Can it just be blanked off, will it affect the running of the motor, what do you do with the vacuum lines?
The car runs OK, but does like to visit petrol stations.
Thanks again,
Col.
Post by Tony From West Oz » Tue 31 Oct, 2017 10:24 pm
Thanks again,
Col.
Yes, adding a blanking plate will improve power or economy (a bit hard to get both at the same time). If you use the improved power, the economy will drop.
Soak the broken stud with "Penetrene" or similar penetrating lubricant. Drill a hole suitable for an "Ezi Out" to be used, to unscrew the remains of the stud. Screw in the new stud.
Jader1973
Post by Jader1973 » Sun 27 May, 2018 11:16 am
Thanks,
Col.
I was just wondering where you go to with this? I assume you replaced it with something?
My 1982 280TE has done exactly the same thing. Based off a search of a slightly dodgy Russian EPC site and a look on Pelican Parts the part number for the gasket is 1041420480. However the image on Pelican Parts looks nothing like the multilayered gasket that is already there - it is a much thinner metal gasket.
I'm a bit stumped.
Thanks.
mathuisella
Post by mathuisella » Mon 28 May, 2018 10:48 am
I'm on the thoughts that blocking EGR is better for engine longevity. not feeding your exhaust waste back into the inlet....
nea100
Post by nea100 » Mon 28 May, 2018 2:22 pm
I did as Tony suggested and made up a blanking plate and cut a gasket, and used some sealant.
Had to drill and tap out the header as one of the studs had rusted off - cause of problem. Fitted new bolts from a local bolt shop.
All good now and no more ticking noises.
Still don't know what to do with the vacuum line but the car starts and runs just fine.
Post by Bartman4800 » Mon 28 May, 2018 2:44 pm
I think Tony's idea was to put a blanking plate on the hole, and get rid of the EGR valve altogether.
Remove the vacuum hose and make sure it is blocked (to avoid sucking in false air)
Post by Tony From West Oz » Mon 28 May, 2018 3:09 pm
Removing it would cause failure of emissions inspection of roadworthy check in most cases, although it may not have the "smog" pump in operation either.
Blanking it and reconnecting all vacuum hoses makes it look original, but your engine and the environment will be better off for doing it.
Jader1973
Post by Jader1973 » Mon 28 May, 2018 7:55 pm
Thanks! That is a huge help.
