Compression Test Suggestions
peterac
Post by peterac » Sun 02 Jul, 2017 7:28 am
I have a rough idle that is driving me round the bend. It has gone on for too long and I need it sorted as I won't put any more money into keeping the car if compression isn't up to scratch.
Note: car is 1980 300D, valve clearances done, engine mounts and trans mount fine, filters changed, car polished. Tea pot blow by test oil cap sits still. It only has a faint light grey haze of smoke from exhaust noticeable in rear vision mirror at night in trailing car lights when I'm at higher end of revs. Car has 800,000kms on it on original motor no rebuild. One glow plug was buggered last week and starting was shocking but it did start cold, rest of the day was fine. Glow plug replaced and holes reamed out and all is good again. New injectors were put in last year by a diesel injector specialist but no difference.
So next step is the compressio test. What is the cheapest way to get this done. Buy a kit, borrow off one of you guys, advice please!
I have rust and panel work that will cost over $2000. Not worth it now if engine is not a keeper.
Thanks as always.
Peter<><
1980 300D
1979 300D (organ donor)
seventyeight
Re: Compression Test Suggestions
Post by seventyeight » Wed 12 Jul, 2017 3:37 pm
I bought a diesel compression tester from Super cheap here in NZ for $100...make sure you do a valve adjustment first of course
800,000 is bloody impressive but don't be surprised if you get poor readings, I tested a couple cylinders on a '77 300D with 500,000 and were below 220 psi, didn't bother with the rest...
1977 250 parts car (drivetrain for sale!)
1977 280>300D conversion
1978 300D Turbo'd and 5 speed - not quite road legal
tsharkey
Post by tsharkey » Wed 12 Jul, 2017 6:58 pm
Hi Peter - Didn´t you have an inexplicable diesel leak - Did you ever solve that - It looked like it could be one of the pre-chambers is not quite right and they can cause rough idle if they are leaking.
Compression test isn´t hard (just about to do one on my new toy) and the kits aren´t expensive - As the man across the ditch says, make sure the valves clearances are A-OK .
peterac
Post by peterac » Wed 19 Jul, 2017 7:13 pm
The leak was fixed, just removed, checked (all was fine), replaced and then no leak. Unfortunately it had no bearing on the idle. Any suggestion on what is the cheapest kit that would be ok but not dodgy?
Peter<><
1980 300D
lockiedog
Post by lockiedog » Mon 20 Aug, 2018 8:17 pm
Peterac did you and up sourcing a compression tester and if so what did you find? I am hoping to test one of my 300d's in the next couple weeks as I am changing the injector nozzels and thought it would be a good chance.
1984 300D Auto Manila beige
1979 240D Manual Light ivory
1976 300D Auto Mimosa yellow
1978 300D Auto Sahara yellow
