Rattling Rear Panel
TheTherapist
Model you own: w211
Rattling Rear Panel
Post by TheTherapist » Sun 16 Mar, 2014 3:04 am
Hi guys,
I have the 10 speaker Harman Kardon Command system in my W211 E55 and for a stock system it sounds full range and quite punchy. Only issue I have is when the volume is turned up the rear parcel shelf makes that brrrr rattling noise. Initially I assumed it was the speaker needed replacing but upon checking further I discovered the noise could be eliminated with firm pressure applied to the cover that clips in across the parcel shelf. The cover is clipped in tightly and appears to be connected fine (same as factory I would imagine) but this noise really detracts from the audio quality. I can think of no way to tighten it or add cushioning to eradicate the rattle. :dontknow:
Has anyone experienced similar and discovered a solution...? :offtheair:
Image Image
W211 AMG E55- The Black Panther - What A Beast!
W124 260E- Straight - Reliable - Clean Ride[sold]
W126 380SE- The Limo - Smooth Cruiser - Pimpin with Gold Paint, Blacked-out Windows & Chrome Trim[sold]
W123 280E- Great Car - Solid - Reliable - Best Internal Acoustic Environment (Gotta have good music)[sold]
Re: Rattling Rear Panel
Post by Greg in Oz » Sun 16 Mar, 2014 11:27 am
The source of the noise will be where that panel contacts another panel or object. I would suggest attempting to find any points of contact and inserting a cushioning material to prevent the vibration.
