OM606
OM606
Post by Mercmad » Wed 11 Nov, 2015 11:17 pm
Re: OM606
Post by AMG » Thu 12 Nov, 2015 2:51 pm
There are a load of OM606x swaps around.
G-wagens are flavour of the month here in OZ, but also there's a 116 280S that JG is doing at the moment.
They are common replacement engine for series Land Rovers / defenders and RRC's in the UK. I've often thought about ditching the 3.9 BendOver v8 in mine and going for the superior reliability of Axis Power. :nono: :occasion5:
heh. Ol' Blighty sure made some rusty junk, but there are some redeeming qualities. :liar: Like err... ummm.. now I'm stuck for words :laughing6:
Re: OM606
Post by TheMadRacoon » Thu 12 Nov, 2015 7:37 pm
AMG wrote:Ol' Blighty sure made some rusty junk, but there are some redeeming qualities. :liar: Like err... ummm.. now I'm stuck for words :laughing6:
'Tradition', old boy, 'tradition'....that's the word you're looking for!
Re: OM606
Post by AMG » Fri 13 Nov, 2015 12:53 am
Hahahaaaaa.
Tradition, yes!
- in the tradition of 'failing to proceed' :laughing5:
instead of the less politically correct but more appropriate SNAFU ?
:laughing6:
I do like the comfortable ride of the Rangie. It's almost Mercedes w123 , but with a bit more body roll.
the 4 speed ZF 4hp22 automatic is very smooth and efficient. The Bw35 transfer case is smooth and quiet and the viscous centre diff is great.
The 3.9 v8 is a bucket of bolts, and the one in mine is a good one. Yet I'm comitted to re-powering it, as it's a gutless waste of fuel... Whether thats replaced with the M117 220kW 560 v8 & 722.3 I have gathering dust, or an OM606a and 722.6, I'm sure the bendover v8 will be destined to live it's life as a boat anchor.
Yep, should have bought a 300GD w460. Not as comfortable though.
anths
Re: OM606
Post by anths » Tue 01 Dec, 2015 4:10 pm
I would drop a om606 or 605 into the w123 at the drop of a hat if they were cheap enough brilliant engines
Re: OM606
Post by AMG » Thu 03 Dec, 2015 7:42 pm
The 606 engines are cheap enough, but the IP isnt easy to find... need one from a 603a to make life easy.
anths
Re: OM606
Post by anths » Thu 03 Dec, 2015 9:51 pm
for sure that easiest way to do it, same with the om605 and it's pump, swap it out for a m/ mw and good to go :)
3DB
Maybach
Re: OM606
Post by 3DB » Thu 03 Dec, 2015 9:58 pm
some pretty compelling viewing there from Diesel Pump UK
AU$1,400 or so for one of their turbo manifolds
add in the 500hp turbo kit for another AU$1,000
then add another AU$2,600 for a high flow injector pump
You could build a bolt-on diesel rocket for under $10K including car.....transmission explosions notwithstanding
damn the AU-GBP exchange rate....
3DB
Return to “The MOD Squad”
