190E 2.3 Lights dulled then it stopped
Digger11
Post by Digger11 » Wed 31 May, 2017 6:08 pm
I am guessing either battery or alternator.
Lights got duller and duller for about 15 minutes as I was driving and then it just stopped.
Any source for a recon. Alternator in Melbourne ? I can fit myself to save $'s
thanks
Digger
Re: 190E 2.3 Lights dulled then it stopped
Post by AMG » Wed 31 May, 2017 6:59 pm
Take yours out and have it refurbed.
Don't get an exchange unit - they aren't the same.
Not a lot to them, should not be expensive either.
Brushes, slip ring, bearings, and a cleanup.
Post by Tony From West Oz » Wed 31 May, 2017 9:32 pm
I don't know if the 190E has the same regulator arrangement as the W123, but for the W123 you can purchase a regulator which just screws into the back of the alternator. It includes new brushes and is just a 10 minute hob to swap out (on a W123).
Might be the cheapest repair you ever do. Much cheaper than paynig an auto sparky hundreds to do it for you.
Digger11
Post by Digger11 » Thu 01 Jun, 2017 8:05 am
Thanks Tony and AMG - kind of surprised that the alternator went so early - car has only done 90,000 easy kms.
Will try the regulator and brushes route - putting in a new battery first as existing is greater than 5 years old - don't think will fix the problem though.
Forum sponsor for the regulator and brushes ? Are they still active ?
Post by AMG » Thu 01 Jun, 2017 9:11 am
Auto sparky / local auto elec parts store / ashdown ingram for reg-rec. get a made in germany one not the chinese crap or you'll be at it again in 12 months.
Forum sponsor can sell you a complete alternator if you need.
Digger11
Post by Digger11 » Thu 01 Jun, 2017 7:43 pm
Sparesbox had a Bosch regulator for $75 so bought that. Replaced battery as was 10 years old (big battery for a small car) but still only 12.6v.
Looks like i can replace new alternator regulator without removing the alternator , from below. Anyone alse tried this ?
Cheers Digger
Post by Tony From West Oz » Thu 01 Jun, 2017 10:47 pm
Digger11, yes, I have replaced the alternator regulator with the alternator in the car (on a W123 300D). A bit awkward getting light and my head to where I could see (glasses on too) and do the job. Much easier than R&R alternator though.
Digger11
Post by Digger11 » Fri 02 Jun, 2017 1:04 pm
Thanks Tone, I'll give it a go on the weekend, looks easier to get to from underneath so I'll pull out the ramps and have a crack.
merc-304
Post by merc-304 » Fri 02 Jun, 2017 1:51 pm
Digger dont forget to disconnect Neg battery terminal before you start
380 SEC
Post by Tony From West Oz » Fri 02 Jun, 2017 3:43 pm
merc-304 wrote:Digger dont forget to disconnect Neg battery terminal before you start
Good point!
merc-304
Post by merc-304 » Fri 02 Jun, 2017 4:29 pm
And if room is not to limited ....clean the contacts that the new reg touch inside alternator.
380 SEC
Digger11
Post by Digger11 » Fri 02 Jun, 2017 5:37 pm
Cheers, both good tips. I am fairly handy around cars, but still appreciate your tips.
I did a course on rebuilding DC motors many years ago that included under cutting the commutator with a cutoff hacksaw blade if I remember right as well as polishing it up with a piece of emery paper I think.
But a long time ago .
At 90,000 kms I will stick to just replacing the regulator/ brushes and trying to see if the contacts are smooth.
Digger
Digger11
Post by Digger11 » Sun 04 Jun, 2017 4:11 pm
Definitely BER. couldn't find a 1 197 311 023 in Aus, so bought a 1 197 311 028. Not sure on the difference, but a post on the UK 190E forum seems to think will work.
If like most Merc parts, the last number is often just sign of an update over the last 27 years.
Do you use an elastic band to hold the brushes in when inserting into the Alternator ?
thanks
Digger11
Post by AMG » Sun 04 Jun, 2017 4:51 pm
If it is a 12V 28mm slip ring n1 / k1 then it will work, but I don't have any x-ref for the max amp output.
Post by Tony From West Oz » Sun 04 Jun, 2017 8:33 pm
thanks
Digger11
No, there is plenty of room for them to wiggle into place.
Digger11
Post by Digger11 » Fri 09 Jun, 2017 11:07 pm
Just to close of the thread, fitted new voltage regulator and 14.2v of charging power.
Far cheaper than a new alternator, and on my 190E 2.3 was easy to reach from the top, 4 bolts and easy.
Post by AMG » Wed 14 Jun, 2017 8:06 pm
Good stuff. Keep an eye on it over the next few weeks, just to make sure the brushes are wearing evenly - looking back at the old pic one brush was badly worn while the other wasn't, it's a sign that there could be shorting in the main winding or the diodes on one of the windings went kaboom.
sounds like the new reg rec fixed the issue, but keep an eye on nonetheless, if your battery is still floating around 13.8 fter a few weeks then it's pretty much a given that all is ok.
Return to “W201”
