Vacuum lines 190D
Don
Vacuum lines 190D
Post by Don » Sat 22 Oct, 2016 5:58 pm
I just picked up a very nice little 190D and it blows hot air on the passenger side but cold on the drivers side. The green and orange vacuum line from the right hand temperature dial is disconnected under the bonnet for some reason and I can't see where it should connect to. It seems too long to plug onto the yellow valve where someone has blanked one pipe off.
If anybody with a 190D could help out with advice or better yet, a pic of where both the green line and the blanked off bit should go it would be much appreciated.
C200 Kompressor
190D
Don
Re: Vacuum lines 190D
Post by Don » Sat 22 Oct, 2016 8:18 pm
Okay, looking at some pics of US cars that green line should go where the brown coloured blank is on the yellow valve.
Some pics of that valve on a local car would still be great!
C200 Kompressor
190D
Post by Tony From West Oz » Sun 23 Oct, 2016 1:05 am
It could be that the vacuum actuator on that side is leaking, and the PO just disconnected that actuator and blocked the vacuum port it should connect to.
Don
Post by Don » Sun 23 Oct, 2016 9:40 am
Thanks! On further examination I discovered the right hand temperature dial has no resistance whilst turning whereas the left one actually feels like it's doing something. Be good if it was just the dial.
C200 Kompressor
190D
Return to “W201”
