Coolant Leak
Blade
Coolant Leak
Post by Blade » Fri 12 Jun, 2015 9:56 pm
Hi All,
I'm new here to the forum and have recently purchased a 1992 180e White, I have just done a radiator flush and replaced the coolant. After I got the engine upto running temperature I opened the hood to check for any leaks, there was a fine mist spraying out, after closer inspection it seems that coolant is leaking from somewhere onto to fan belt and thus the fine mist spraying up. I checked the bottom radiator hose and could not a hole in it. Any ideas as to where this leak is coming from?
Any suggestions would be greatly appreciated.
Re: Coolant Leak
Post by Tony From West Oz » Fri 12 Jun, 2015 11:42 pm
Blade,
Welcome to the Forum.
I hope you will get as much from it as I have.
Regarding your coolant leak, there are a number of possibilities:
One of the radiator hoses has a pinhole leak;
Hose clamps may not be tight enough (unlikely in this case)
Radiator has leak;
Water pump has leak;
Thermostat housing has a leak (alloy corrodes and can cause pinholes in castings);
Other hoses in area have leak;
Other ????
Members who have experience on this particular model may be able to elaborate further.
The best you can do is to look for the leak yourself, or go to a radiator shop and have them check out the issue. They can pressurise the system by connecting an air pump to the radiator cap.
Re: Coolant Leak
Post by Ivanerrol » Sat 13 Jun, 2015 12:02 am
Unfortunately radiators from that era had a common problem of breaking off at the location where the top hose connects to the radiator.
The radiators are partly made from plastic. To keep this plastic in good shape and not let it go brittle it's essential
to use the proper MB spec radiator coolant.
here's some images
Your radiator maybe on the way out. There is no fix for this - you need to buy a new radiator if this is your issue.
Blade
Re: Coolant Leak
Post by Blade » Sat 13 Jun, 2015 9:32 pm
Thanks for the information much appreciated, will try again tomorrow to locate the leak. The radiator is good, thermostat housing is good, will check water pump and bottom radiator hose.
Return to “W201”
