wiper motor lubrication
Jake
Model you own: w115
Post by Jake » Fri 25 Jul, 2014 9:08 am
In the process of replacing the electric fan motor , I decided to check over the wiper gearbox, there is some pretty dry pale yellow grease in there, it's not doing much good .
The shaft and sliding bars run against what looks like a hard plastic medium and I want to know if there is a recommended lube for this part.
Thanks for your thoughts.
There is a fine line between hobby and mental illness .
Re: wiper motor lubrication
Post by Ivanerrol » Fri 25 Jul, 2014 10:00 am
I use White Lithium grease although it gets messy and needs to be done every year or two.
I have read that M.B. sliding roof lube works wonders and lasts more than a few years. (But expensive)
Also Molycote 33 from one of the big barn auto shops.
crazycrowbar
Post by crazycrowbar » Wed 24 Jun, 2015 12:13 am
Ivanerrol can you please advise how and where to put in the grease?
seems to me like a sealed unit.....saw this on youtube......
Please copy and paste ................
https://www.youtube.com/watch?v=W3IPjKg ... 2&index=20
Is it really necessary to take everything of the car and open it up?
S124
Post by S124 » Tue 30 Jun, 2015 8:58 pm
crazycrowbar wrote:Ivanerrol can you please advise how and where to put in the grease?
Absolutely. I was in the process of making a DIY for this but then I spilt wine on my laptop and killed the HDD.
I've still got a few pictures left of the process, but need to resize them for upload. There is a bit of a knack to it, but once you have done one it becomes all too easy.
I use Nulon Xtreme performance grease. You will need to clean out the inside gears and dry then apply the grease to the gears and also the sliding rails under the front cover.
1993 DCII Ford LTD V8. 5spd, H/C/I. Cardinal Red
1992 201.024 Mercedes 190E-24 M104 Project BrilliantSilber
1995 124.092 Mercedes E320 Wagon SaphirSchwartz
OzPaul
Post by OzPaul » Fri 22 Jan, 2016 10:59 am
There is indeed a knack to opening the unit, but not dificult. It is important to mark all moving parts relative to each other to assist phasing and re-assembly - paint dots or small scribe mark. From memory you have to get the actuating arm half way through it stroke to separate the main mechanism. In particular, this is where you have to be sure when reassembling that you are re-engaging the internal gears on the same teeth. Had good success using Penrity SIN synthetic grease for lubrication. I was advised that it will not go hard over time to the same extent as other greases.
Return to “W201”
