Stuttering 190E
Hendrik
Stuttering 190E
Post by Hendrik » Mon 07 Jul, 2014 10:07 am
My Mums 190E is being a pain at the moment.
When you go to take off it will stutter/hesitate/misfire and nearly stall, however once it gets going it seems fine, above 1200 or so revs.
Haven't had a chance to put in the workshop for some serious looking at.
Any ideas?
Re: Stuttering 190E
Post by pastelgrey300D » Mon 07 Jul, 2014 10:50 am
With all the wet/damp weather we have been having lately could be moisture/corrosion in the distributor cap and/or spark plug leads where they connect to the dizzy cap / coil? Sounds like it might also be a coil issue?
Re: Stuttering 190E
Post by TheMadRacoon » Mon 07 Jul, 2014 12:05 pm
If it's K-jet (maybe all 190s are?) then could it be the fuel distributor?
Hendrik
Re: Stuttering 190E
Post by Hendrik » Mon 07 Jul, 2014 12:28 pm
Tried a spare dizzy cap, no better, also tried another couple of FPRs but that ain't no good either.
It just seems that the spark is not advancing/retarding when you put your foot down and there is a strongish fuel smell coming out of the exhaust which sort of points to that as well.
SuprHasan
Re: Stuttering 190E
Post by SuprHasan » Fri 18 Jul, 2014 2:59 pm
I have read of a few identical cases where the culprit was a worn potentiometer. This issue is something I also need to diagnose in the 16v.
Unfortunately they aren't available new from the dealer.
Fortunately you can get a reverse engineered unit from Team Stadler Motorsport in Germany for €160
http://www.190teile.de/serienteile.php
SuprHasan
2012 C250 CDI Wagon(Sebastian)
2006 Peugot 307 XSR HDI (Sophie)
1988 190E 2.5-16 (George)
1996 Jaguar XJ6 X300 (Kitty)
TwentyFiveSixteen.com - A blog about a Benz
Re: Stuttering 190E
Post by AMG » Fri 18 Jul, 2014 7:59 pm
Hendrik,
Is the fuel smell accompanied by a decent amount of black smoke - difficulty starting and idle rpm behaviour, and light throttle? but under medium - hard throttle it takes off like there is no issue?
(possibly a leaky fuel divider or injector)
Also check the IAC, just disconnect the plug and see if the idle changes - smooths out.
Just some things worth checking. I'd guess you've probably explored those avenues already.
Also check the EHA for leaks.
Jelfes
Re: Stuttering 190E
Post by Jelfes » Sat 19 Jul, 2014 6:22 am
Hasan,
You can get an original Bosch Potentiometer from this place in the UK. I got one last year.
http://www.ebay.com.au/sch/m.html?_odkw ... 2&_sacat=0
SuprHasan
Re: Stuttering 190E
Post by SuprHasan » Sat 19 Jul, 2014 6:14 pm
Wow, I thought they were NLA. Thanks for the info.
SuprHasan
Jelfes
Re: Stuttering 190E
Post by Jelfes » Sun 20 Jul, 2014 7:26 pm
To ensure you order the right unit for your car, You will need to message the seller with the part number that's stamped on your original unit to get the right one as the Bosch part numbers have changed. I had a part number cross reference list somewhere. If I find it I will post it for you.
Jelfes
Re: Stuttering 190E
Post by Jelfes » Mon 21 Jul, 2014 5:56 pm
Here is the Bosch Potentiometer part numbering cross reference.
SuprHasan
Re: Stuttering 190E
Post by SuprHasan » Mon 21 Jul, 2014 8:00 pm
Thanks for the info. Never thought of that.
SuprHasan
crazycrowbar
Re: Stuttering 190E
Post by crazycrowbar » Wed 24 Jun, 2015 12:02 am
Mate Ive had the same problem with mine up until Saturday, like my car was serious suffer from Parkinson's Disease.....
Exactly as you describe it....Seems worse when in reverse and park......However mine started about 15 -20 minutes after driving.....I've replaced the dissy cap....Problem solved......Hoora!!!!! Make sure if you wanna take the same course of action....2 diff dissy caps.....One for models with and without cat converter.....hope it helps......
Return to “W201”
