W203 - c180 / 200 - MY05/06/07 buyers advice
stunkat
Post by stunkat » Sat 01 Sep, 2018 6:43 pm
Evening All
First time poster to this section of OZBENZ and I'm looking to put my recently licensed daughter into the safest sedan / hatch I can under $8k and was drawn to the later w203's with 10 airbags, etc. The kompressor models seem to be value atm but that makes me a tad nervous....do they hold any specific gremlins, etc a buyer should be aware of ?
More broadly, any feedback / issues with the later w203 models is also very much appreciated.
Stunkat
Re: W203 - c180 / 200 - MY05/06/07 buyers advice
Post by Ivanerrol » Sat 01 Sep, 2018 8:29 pm
Make sure you have the engine checked out.
The late W203's and early W204 M271's had issues with the balance shaft.
Read all about it here : http://australiancar.reviews/reviews.ph ... =603&pno=0
Read the whole review on the W203.
If you can stretch the budget post 2008 W204 are much better cars. There are hundreds for sale on the usual sites.
stunkat
Post by stunkat » Tue 04 Sep, 2018 5:15 pm
Thanks for the advice and the link to the review....much appreciated.
Don't think I can stretch it to a w204 but maybe one of the normally aspirated w203's with the 6....
Stu
johna
Post by johna » Fri 21 Dec, 2018 2:41 pm
The M271 engines suffer from timing chain issues. They are a flimsy single row chain and are expensive to replace, which is a common complaint. The earlier W203s with M111 engine are better for reliability.
W202 2000 C200T Elegance
Post by Ivanerrol » Fri 21 Dec, 2018 8:21 pm
M271 engines had timing chain issues right until the end of production.
EEuroparts in the U.S. made up a kit with much better components.
M272 engines had much better quality after early 2008.
If you are after a C class. Don't bother with a W203. Just get a post 2008 W204
