M272 airbox.
M272 airbox.
Post by Ivanerrol » Fri 16 Mar, 2018 11:18 pm
If you have a M112 or M272 engined car, make sure if you remove the MAF or airbox then be very careful install them back properly.
Otherwise air leaks can occur and throw codes.
Specifically 0171 and 0174 codes.
Check engine light comes up on the cluster to sufficiently scare you.
If you don't have a scanner/reset device then a trip to the stealership/independent service agent will cost you $$$$
