Buying advice for C250
benzage
Post by benzage » Sun 02 Apr, 2017 7:49 pm
Hi everyone
I am looking at purchasing a 2012 C250 sedan and was hoping to get some advice on any notable things to look out for during inspection.
Even some general info and feedback from current or previous owners on the C250 would certainly be valuable.
Many thanks in advance [emoji4]
Sent from my iPad using Tapatalk
Re: Buying advice for C250
Post by Ivanerrol » Sun 02 Apr, 2017 10:15 pm
(a) Make sure service records are up to date.
(b) Check service records to make sure injectors have been changed (if you are looking at a C250 diesel).
(c) make sure you get a scan done.
(d) be aware of the major depreciation.
others may chime in.
Starman
540 K
Model you own: w211
Post by Starman » Mon 03 Apr, 2017 9:18 am
More important is the test drive. Check for transmission shifts smoothe both up and down. Check dash display for any error codes, watching closely on start-up. Beware of ANY aftermarket fittings from wheels through to multimedia, nothing works as well as original MB kit does, nothing.
W212 E400 Avantgarde
W211 E500 Elegance sold
W202 C200 "the Tank" sold
benzage
Post by benzage » Mon 03 Apr, 2017 9:40 pm
Thanks for your prompt replies guys, much appreciated [emoji106]
I'm looking at the C250 petrol model, sorry - should have mentioned that in my first post.
Just regarding the scan, what exactly is this?
Where can I get it done?
I'm guessing it's a diagnostic scan of some sort?
I would like a mechanical inspection prior to purchase, can anyone recommended a MB specialist in Sydney?
Thanks again
benzage
Post by benzage » Mon 03 Apr, 2017 10:10 pm
Duplicate post
scorchi0
Post by scorchi0 » Tue 04 Apr, 2017 6:01 pm
Diagnostic scan can be done by any competent mechanic, though an M-B specialist would be the choice of course.
It's already been mentioned, but make sure servicing has been done. Gearbox is to be serviced once only at 3years or 50,000km which often gets missed on the grounds of cost. Plugs and air filter are 4yrs/75,000km...
Image Image
benzage
Post by benzage » Mon 10 Apr, 2017 9:36 am
scorchi0 wrote:Diagnostic scan can be done by any competent mechanic, though an M-B specialist would be the choice of course.
Thanks Scorpio for your informative reply.
Just on the servicing side of things:
What brands/types are recommended for -
Oil filter
Fully synthetic oil
Spark plugs
Could you also recommend any MB specialists in Sydney to carry out a mechanical inspection and servicing that use OEM parts?
scorchi0
Post by scorchi0 » Fri 28 Apr, 2017 8:34 am
Can't help you with a specialist in Sydney as in in Perth.
For oil filters I'd stick with Mann-Filter (who supply M-B for the genuine filters), Hengst, Mahle or Knecht.
For plugs, I'd say Bosch or NGK.
For oil, any decent brand really - so long as it is 5w-30 and meets the Mercedes-Benz 229.51 spec. M-B use Fuchs GT1 Pro Flex, alternatively there are products from Castrol, Penrite etc that also meet the spec.
Sent from my HTC_0P6B using Tapatalk
Image Image
Post by Ivanerrol » Fri 28 Apr, 2017 4:56 pm
Get the timing chain checked by a MB specialist.
These engines have been known to have weak timing gear.
hm8888
Post by hm8888 » Tue 02 May, 2017 10:56 am
You may be able to get a Mercedes approved car at a very good price. Peace of mind.
I purchased my 2011 that way. Had a minor oil leak which was fixed no questions.
Done just under 80k now and a brilliant car especially if maintained correctly.
Starman
540 K
Model you own: w211
Post by Starman » Tue 02 May, 2017 3:22 pm
My new one is a Mercedes-Benz Certified Pre-Owned vehicle, came with a full MB two-year warranty. Price was very good too.
