Cleaning the Interior
230Easy
Model you own: w901-905
Post by 230Easy » Wed 23 Nov, 2005 11:11 am
Recently purchased a 230E which is great except for cigarette smells. What's the best way of removing cigarette smell from the car interior?
HansKruger
Post by HansKruger » Wed 23 Nov, 2005 6:08 pm
Firstly try leaving al the windows down outside for the day, if that dosen't work, try driving it around for an hour with them all down.
Pet stores or cleaning shops should sell stuff to remove nasty odors.
Assume it's MB Tex, want to double check they are safe on this.
May also want to ditch the floor mats, get some new ones and give the carpet underneath a good clean with a quality carpet cleaner.
Hang a few air freshners inside your MB and you should be in business.
O319-coach
Mercedes Guru/Admin
Post by O319-coach » Wed 23 Nov, 2005 7:28 pm
Depends how bad it is. I have had cars we traded that i have wound up putting another interior into. Ciggarrette smoke gets into everything and is very hard to remove.
Hanss idea about windows down and outside in the sun does work to some extent but needs more than just a few days.
Independent importer of discounted genuine Mercedes-Benz parts.
Restorer of Concours winning cars.
Sponsor of this forum.
http://www.mbspares.com.au Toll free phone 1300 787 300
bruceT
Post by bruceT » Wed 23 Nov, 2005 8:47 pm
Not long ago, somebody turned off our big freezer in the garage by mistake. It was 2 weeks before this was discovered. Words can't describe the odour that greeted me when I opened the door........
After the mess was cleaned out, (believe me, meat is 99% liquid) we were considering throwing the freezer onto the tip because the smell would not dissipate. But a few bags of silicon gel cat litter placed in trays absorbed all the odours within a week and the freezer was as good as new.
Worth a try.
Bruce
http://oztayls.blogspot.com/
http://oztayls-shesha.blogspot.com/
Past Benzs:
1976 W123 300D (Running on SVO (Straight Veg Oil) since June 2006-Sold in Nov 2008)
1982 W126 280SE - Unregistered (Free to a good home!)
1993 W124 300D (running on 100% used cooking oil, no conversion and no glow plugs!)
OzBenzHead
Post by OzBenzHead » Wed 23 Nov, 2005 9:30 pm
bruceT wrote:... a few bags of silicon gel cat litter placed in trays absorbed all the odours within a week ...
So cats do - if indirectly - have a use after all! :wink:
OzBenzHead
Currently owned:
1965 W112 300 SE/C
1983 C126 380 SEC
and formerly:
1955 W180 220a
1965 W111 220 S
1970 W108 280 SE (my first Benz)
1973 W116 280 SE Crayford Estate (previously owned by Rolf Harris)
1980 W116 280 SE
1989 W124 300 E
1992 W201 180 E
1992 W201 190 E 2.0
+ numerous W108 and W116 rolling spares
and prior to my M-B enlightenment:
53 other cars of many nations, but mostly British oil-leakers (including 14 Rovers of the 50s and 60s) cursed by Lucas the Prince of Darkness. First car owned (at age 13): 1953 Fiat. Learned to drive in: 1927 Nash utility paddock-basher & Grey Fergie tractor. Driven distance (logged as at 30 June 2016): 4.6 million km.
76Benz
Post by 76Benz » Wed 23 Nov, 2005 11:16 pm
They did this on Mythbusters not long ago except they were experimenting with dead person smells. They used a couple of pig carcases instead and left them there for 6 months.
At the end of that they tried everything to get rid of the smell but to no avail. They ended up stripping the entire car and selling the body and engine to some enthusiast. The problem was that the odour had got in everywhere including th ventilation system.
Doubt your problem would be that bad. Nilodour used to work OK ion a house when I lived with a smoker
Seinfeld also had a similar episode with BO, think they trashed the car as well.
Good luck
Kurt
230Easy
Post by 230Easy » Thu 24 Nov, 2005 8:54 am
Thanks guys it's not as bad as rotting corpses! However I think it need a little more than windows down - I've vacumed the interior and cleaned the carpets etc and although it's much better there is still some resudual smell. Kitty itter sounds good.
Post by 420 SE » Thu 24 Nov, 2005 4:04 pm
My brother in law is a car dealer - they put fresh coffee beans in a dish under the seats for a few days, and it works!
My car came from Hong Kong with 17 years off smoking smell in it. I put fresh, unused coffee beans in for admittedly a couple of weeks - but it did the trick.
thepast123
Model you own: w221
Re: Cleaning the Interior
Post by thepast123 » Mon 23 Oct, 2017 8:14 pm
Hello,
I just recently cleaned mine using my household Bissel Heated Carpet Cleaner, using the standard bissel carpet cleaning solution. My carpet clean has a hand attachment and I used that throughout the inside. It got rid of the majority of the dirt and mildew and I'm very happy with the appearance now.
Post by Ivanerrol » Tue 24 Oct, 2017 12:37 am
Hello,
Modern appliances have come to the fore.
Carpet cleaners and Steam cleaners are now consumer items.
I use my household Karcher Steam cleaner to clean the carpets,
edenning
Region: South Australia
Post by edenning » Tue 24 Oct, 2017 8:28 am
Not sure what year your car is, but if it's got a cabin filter I would be thinking about replacing that as well.
