Distributor Colour Code
cjhols
Post by cjhols » Sat 12 May, 2018 2:40 pm
oooops. I inadvertently pulled the connector apart ( to clean)that leads from the bottom of the distributor and now I don't know the order and corresponding 5
wire colours. There are 6 holes but only five wires ??? The colours are green, black, red, yellow and white.
O'h and does anybody know the name of this connector?
Peter
1973 SLC 450
1971 Clubman Mini
Chai
Re: Distributor Colour Code
Post by Chai » Sun 13 May, 2018 9:14 pm
D-Jet trigger points plug to the wiring loom.
You're lucky I found this piece of paper in my store room, saved from when I had to replace the plug a long time ago.
Chai
1974 450SLC
cjhols
Post by cjhols » Sun 13 May, 2018 10:12 pm
Awesome i assume the my yellow that i have would go where your blue goes? Do you know the name of the connector ?
Peter
1973 SLC 450
1971 Clubman Mini
Chai
Post by Chai » Mon 14 May, 2018 8:24 pm
I don't know the name for this connector type.
My car's a '74 and can't explain why there's a yellow coloured wire instead of blue in your '73.
Chai
1974 450SLC
cjhols
Post by cjhols » Mon 14 May, 2018 10:32 pm
Hmmm I tried to connect it as I thought but it ran like a dog - had to have the accelerator flat. It seemed flooded coughed and spluttered and after awhile it wouldn't run at all. Apart from the connector falling apart and spraying contact cleaner on the throttle regulator on the side of the carbie i havent touched a thing?
1973 SLC 450
1971 Clubman Mini
Chai
Post by Chai » Fri 18 May, 2018 3:04 am
Sorry, not able to help as I’ve just gone away on holidays and unable to provide picture of spare/used trigger points.
Chai
1974 450SLC
