Is 100,000 km between tie-rod replacement means I'm driving too hard?
Post by Chai » Sun 10 Feb, 2019 9:38 pm
My right-hand steering tie-rod has worn considerably. It was a knocking sound from the steering/suspension area when I turned the steering wheel while driving over uneven road surface that led me to look underneath the car.
Checked my service records and the right-hand inner tie rod was replaced ~100,000km ago.
The other (left hand) tie rod was fine - firm and not loose.
Am I turning left harder than I turn right that's causing the right-hand tie rod to wear faster?
aleks001
Re: Is 100,000 km between tie-rod replacement means I'm driving too hard?
Post by aleks001 » Mon 11 Feb, 2019 9:44 pm
Don't over think it. It's too hard to answer these questions anyway, everyone drives differently and hits different things in the road on a daily basis. Personally I would be happy with replacing tie rod ends every 100,000KM.
Post by Ivanerrol » Mon 11 Feb, 2019 10:43 pm
Not if you are driving a contemporary Benz.
The W204 I have is notorious for going through front suspension parts before 100,000K's.
There were design faults in the W203 suspension that carried on through the w204 series.
(B) I have had to to do balljoints and tie rod ends in a car where I put oversized wheels and tyres on.
Djenka018
Post by Djenka018 » Tue 12 Feb, 2019 5:06 pm
I did draglink and tierods at 45000km
and it was overdue long time.
Now at 90000km and still good.
Garage life, i guess, the car sat undriven for several years.
Perhaps the RHS wheel is hitting more potholes or shopping mall speed humps drive around (i do them perpendicular and both wheels simultaneously)
'80 450SLC 3-continental
