You can check it out here:
http://www.mbspares.com.au/Information/ ... o-121.aspx
M.B Spares Newsletter No.121
- OZBENZ Admin
- S Class
- Model you own: w124
Re: M.B Spares Newsletter No.121
Hi John
Every year when summer comes I need to regas my aircon (95 E280 W124). Last summer I had the mechanic put dye through it but there was no sign of a leak. But still no cold air this year. So obviously in the evaporator. Heard about your $400 fix and am interested but live in Melb. Any suggestions. (Usually take my car to Gullwing Motors in Blackburn)
Joe
Joe
- yellowsub
- Adenauer
Sorry for jumping in, but once you get it fixed make sure you run your a/c compressor for at least a few minutes every week - including the cooler months - so that the lube gets circulated (it is mixed with the gas). Used to do air-con and probably the most common cause of perished seals, corrosion and siezed compressors was from lack of circulation due to people not using the air-con in autumn and winter.suitcaseau wrote:Hi John
Joe
Funny, we weren't supposed to tell the customers this :|
1987 W124 300D
1987 W124 300D
- OZBENZ Admin
Suitcase, see the PM I just sent you.
- yellowsub
- Adenauer
Any chance you could let me know about this fix?? Thanks.
1987 W124 300D
1987 W124 300D
