Doors will not close shut
Cream 280SE
Post by Cream 280SE » Mon 16 Apr, 2018 7:02 pm
Hello all
Please help!! Two of my doors will not close shut! The drivers side and the rear passenger on my vehicle.
I have been able to click the lock mechanism around and then it does not close shut! It is as if there is something not allowing the lock to work correctly.
Anyone else had this issue?
Darren
Chai
Re: Doors will not close shut
Post by Chai » Mon 16 Apr, 2018 7:26 pm
If the door will not shut (closing sounds like the door hit metal) after the roller-like device in the door latch was moved, then that roller should be moved around.
Pull the door opener and that mechanism will then be free to move around. This information is recalled from very long-term memory as I also did this long ago.
Chai
1974 450SLC
Post by CraigB » Mon 16 Apr, 2018 7:33 pm
Yes if the door is open and you pull the handle (inside or out) then that lock you rotated should release and open. They can get stiff though and might need a little help with a screwdriver or even pull off and lubricate lock.
Cream 280SE
Post by Cream 280SE » Mon 16 Apr, 2018 8:28 pm
Thank you, will try these suggestions.
Darren
Lance
Post by Lance » Mon 16 Apr, 2018 9:29 pm
Maybe the plastic bit broke on the striker mounted on the pillar, that has happened on my W123 is W116 similar? If so then replace striker.
Lance Smart
W114 280E 5 speed manual
W123 280E
Cream 280SE
Post by Cream 280SE » Tue 17 Apr, 2018 7:09 am
Thanks Lance
Post by Tony From West Oz » Tue 17 Apr, 2018 11:56 pm
Are these still available? Are they the same for Front, Rear, Left and Right?
What are they worth? What do they cost? (LOL)
Cream 280SE
Post by Cream 280SE » Thu 19 Apr, 2018 7:14 pm
Gday Tony, I found out today that they can be ordered, brand spanking new!!!! That’s great!!
Problem is,..........they are $180.00 EACH!!!
Post by CraigB » Thu 19 Apr, 2018 7:47 pm
That's ridiculous - similar aftermarket item for landrover defender, but good quality and work because i bought some - $15. I know thats different quantities etc etc, but even from dealer in the past there was some logic with pricing - now it seems to be 'pick a number' and then they must roll around on the ground laughing about how ridiculous it is!
Lance
Post by Lance » Thu 19 Apr, 2018 7:48 pm
I got a good second hand one from Merc bits in huntingdale.
Lance Smart
W123 280E
Lance
Post by Lance » Thu 19 Apr, 2018 7:49 pm
Genuine MB stuff is available for reasonable prices from MB classic USA or Pelican Parts.
Lance Smart
W123 280E
Cream 280SE
Post by Cream 280SE » Sat 21 Apr, 2018 10:01 am
I had this quote of 180.00 + GST from Silver Star Spares at Kingsgrove. They are quite reasonable regarding their prices.
I would hate to think what a Mercedes Benz stealership would charge!
Return to “W116”
