Plastic Bar Links
Cream 280SE
Plastic Bar Links
Post by Cream 280SE » Sat 14 Apr, 2018 6:27 pm
Hello all!
Ok, I noticed that the original metal bar links that attached from the rear sway bar to behind the rear wheel brake area where just swaying in mid air.
I purchased a new set which are nylon or plastic.
Now my problem is.... the original steel ones were attached by a screw behind the rear brake area, so I could unsrew it as the original was just so buggered, and the top one was attached using a nut.
Now the new ones have a nut for both the top and the bottom, so how do I attach this bloody thing?
I don’t even think I’m making sense here!!
Daz
Re: Plastic Bar Links
Post by John Green » Thu 19 Apr, 2018 9:13 pm
The original metal ones are still availble. I have some left if interested.
Cream 280SE
Post by Cream 280SE » Fri 20 Apr, 2018 4:59 pm
Hi John
Called today , but you were flat out. Left message
Darren.
Post by John Green » Fri 20 Apr, 2018 7:30 pm
And now I am on a weeks leave, one of my staff will call you back.
Return to “W116”
