Tuning a 77 280SE
Cream 280SE
Tuning a 77 280SE
Post by Cream 280SE » Sat 07 Apr, 2018 9:02 pm
Hello all
Can anyone here assist me with how to tune my w116 280 Se 1977 model?
It’s rough running .
Darren
Re: Tuning a 77 280SE
Post by John Green » Sun 08 Apr, 2018 9:19 am
There is only so much that a home mechanic can do. So do all the basics first:
- Check the valve clearances, fit new rocker cover gasket.
- New spark plugs, keep in order and even take a picture of them all together, just to remember.
- Check condition of distributor cap and rotor button, replace if at all suspect looking
- Check leads for resistance, the lead itself should be copper core (not silicone) so it should have no (or very little) resistance, the resistance is in the plug connectors
- While checking leads have a look inside the plug connector to make sure it is clean and making a good contact with the plug
- Check vacuum advance is working
- Set timing (should have sticker on radiator support if it is a 1977>>> model
Beyond that you need a gas anylizor to set the air fuel ratio.
Cream 280SE
Post by Cream 280SE » Mon 09 Apr, 2018 6:28 pm
Hi John
Thank you!
If I could get it down to Canberra , it would be there yesterday!!!
I’m on the Central Coast, will call you tomorrow.
Return to “W116”
