300d injection blues
1935-1953: 170V, 170S, 170SAC, 170SBC, 170Va, 170Vb, 170S-V, 170S-D, 170D, 170Da, 170DaOTP, 170Db, 170Sb, 170DS, 220sedan, 220a cabrio., 200b cabrio., 220 coupe, type 300, type 300b, type 300c, type 300Lang, type 300d, type 300 S, type 300 Sc,
Blackted
Post by Blackted » Tue 07 Mar, 2017 8:38 pm
Has any one got any information on 300d W189 injection pump. The oil level keeps depleting within 40 km the injection pump sump is empty and then has a mixture breakdown (lean mixture). I suspect the leather diaphragm is past its us by date.
1982 280CE W123 Coupe
1982 300TD W123 Wagon
1971 240D W115 Sedan (sold)
1971 220 W115 Sedan (parted)
1989 E220 W124
1993 C180 W202
2005 CLK55 CAB AMG
Blackted
Re: 300d injection blues
Post by Blackted » Fri 10 Mar, 2017 9:32 am
Update..I have removed the injection pump and inspect the leather diaphragm and it is old but not leaking.
Front cover seal looks to be in good order as well.
1989 E220 W124
1993 C180 W202
2005 CLK55 CAB AMG
Post by TheMadRacoon » Sat 11 Mar, 2017 12:22 am
Sorry I can't answer your question, but I can admire your car. She's beautiful!
Blackted
Post by Blackted » Sun 28 May, 2017 11:26 am
Ok have worked out the oil usage problem on the injection pump.
The fuel lift pump that is attached on the side of the injection pump has turned into a vacuum pump, due to old age and internal wear.
Good news is there is one available.
Bad news its $2000.00 ex Germany.
1989 E220 W124
1993 C180 W202
2005 CLK55 CAB AMG
Post by Tony From West Oz » Mon 29 May, 2017 12:13 am
Surely you can overhaul that pump.
Replacement valves and possibly a seal should do the trick.
Blackted
Post by Blackted » Fri 02 Jun, 2017 8:55 pm
Yes possibly it could be repaired , it is an interference plunger type pump.
I have had it a part and will try and get an internal seal grove or so machined and will use as spare if repairable.
Had to manufacture holding pins etc to reassemble. Fiddly little thing.
New one is on its way.
1989 E220 W124
1993 C180 W202
2005 CLK55 CAB AMG
Return to “W136, W186, W187, W188, W189”
