Where are the R107 drain holes for the cowl and blower box?
berntd
Model you own: w110
Post by berntd » Wed 05 Oct, 2016 1:13 pm
Hello
I have searched across several forums and although it is mentioned everywhere that the firewall rusts out (a problem which I have here), I can't see anywhere where the original drain holes / channels were located. I have seen pictures of them but I cannot make out where on the body they refer to.
Does anyone know where I should be looking?
Bernt
Re: Where are the R107 drain holes for the cowl and blower b
Post by TheMadRacoon » Wed 05 Oct, 2016 1:49 pm
Hi berntd,
This might be helpful. Sort of shows general location of drains
https://www.youtube.com/watch?v=oeMsD0nsdhY
Quite a few videos for SLs from The SL Shop too...
https://www.youtube.com/user/TheSLShop
Hope they are helpful
Post by pastelgrey300D » Wed 05 Oct, 2016 3:02 pm
Does this help?
water_drains.pdf
Post by T-Modell » Wed 05 Oct, 2016 4:47 pm
berntd
Model you own: w110
Post by berntd » Wed 05 Oct, 2016 8:00 pm
Hi Thomas
That is great thank you.
It still does not tell me where the blower box drains are.
It mentions that they egress somewhere in the transmission tunnel but where do they start at the other end?
Are there separate drains for the 2 grilles as well? That is not mentioned.
Hey, I found the tank filler drain :-)
There was a p7ddle of water in there so I ran welding rod down the drain and suddenly all that water pissed into my shoe underneath.
Bernt
berntd
Model you own: w110
Post by berntd » Wed 05 Oct, 2016 8:08 pm
Wait a minute, I just watched that video as per madracoond's link.
That says and shows that the blower box drains through rubber hoses into the sills.
Now I am even more clueless. :dontknow:
Bernt
450sl
Post by 450sl » Wed 05 Oct, 2016 11:31 pm
I vaguely remember that the sides dump in the middle fan box. So the fan box must have the hose.
I suggest you take the fan out (15 min job, just be careful with the electronic connector, and have a look.
Marco
Marco & Sonia
1978 MB 450 SL
Adelaide
My blog 450sl.blogspot.com
berntd
Model you own: w110
Post by berntd » Thu 06 Oct, 2016 8:35 am
450sl wrote:I vaguely remember that the sides dump in the middle fan box. So the fan box must have the hose.
Marco
I did take the fan out earlier this week but the reason I need to know the details is because there is nothing there any more.
The fan studs are rusted off and and I cannot see from what is left where the drains should have been.
I need to repair all this but without info, it will be hard.
You reckon that the side boxes do not have any drains but are supposed to run into the centre box?
That sounds like an invitaion for corrosion, especially if the car is parked at a sloping kurb.
Bernt
450sl
Post by 450sl » Thu 06 Oct, 2016 8:57 am
Well i guess the side ones must also have s hole then that dumps in the sill?!?
Contact Sl shop, they have the repair panels for own use, so perhaps also for sale.
Sorry can't help further as just covered it all up...
Marco & Sonia
1978 MB 450 SL
Adelaide
450sl
Post by 450sl » Thu 06 Oct, 2016 9:57 am
Hi Bernt
Perhaps this link is useful http://www.theslshop.com/mercedes-benz- ... r-kit.html
Marco
Marco & Sonia
1978 MB 450 SL
Adelaide
berntd
Model you own: w110
Post by berntd » Thu 06 Oct, 2016 1:22 pm
Yes thanks. I have written to that shop regarding those bulkhead panels.
The forum sponsor does not have anything in that regard.
I will ghet there...
Best regards
Bernt
Post by AMG » Thu 06 Oct, 2016 7:25 pm
berntd
Model you own: w110
Post by berntd » Thu 06 Oct, 2016 8:15 pm
Excellent, Thank you. No wonder one can't find those!
The 4 long ones seem to come from 8nside the car?
Bernt
Post by AMG » Thu 06 Oct, 2016 8:27 pm
Yes, below the heater box. you can see them on the left side of the bottom picture above. Didn't think to take any pics at the time, was removing non-original wiring harness butchering for car phone and alarm.
In the trans tunnel, the forward-most are drains from the cowl area
then the 4 drains behind are from the front and rear of the heater box. It is a real PITA job to remove - It is literally the first installation item in the chassis, so everything has to come out - a pillar trim, dash, centre console, carpet, the lot.
berntd
Model you own: w110
Post by berntd » Thu 06 Oct, 2016 9:09 pm
Thanks so much. That is the best information I have seen anywhere!!
Do you think the windscreen has to come out to replace the metal in that fan box?
I kind of like a challenge but I won't just dive into the deep end without knowing what I 'm getting into.
Best regards
Bernt
