inaccessible rust
GeeMerc
inaccessible rust
Post by GeeMerc » Mon 04 Aug, 2014 7:54 pm
Over weekend removed seats and flooring to expose floor pan. I was considering using POR-15 to the floor pan after taking wire brush to the rust. There is a welded rectangular hollow piece of metal that runs across the floor pan from centre to the side - not sure what it is called. (see attached images)
I took a torch and looked inside the hollow metal and there was a reasonable amount of rust worse on the left hand side. Wondering how to deal with this area of rust as I cannot reach it. Was considering using something like Dynax S-50 cavity wax. Appreciate advice as to how to deal with this area of rust. Have provided photos that show floor pan with one photo showing the rust inside hollow metal piece
Re: inaccessible rust
Post by T-Modell » Tue 05 Aug, 2014 3:46 am
I would rinse it properly with water to get the dirt out. Then Fertan for 24 hours to transform the rust. Then rinse it properly, put a "creaping" oil (like I used "Fluid Film") to soak all the little cracks and finally after 1-3 days use wax from a spray can.
