Replacing AAV.... do I need Loctite?
Post by TheMadRacoon » Thu 17 Jul, 2014 11:04 am
I am replacing the AAV on the 350SLC. I will replace the spring washers on the hold down machine screws, and adding a new gasket that came with the AAV. The screws came out easily and there was no sealant or loctite on the thread.
Should I add loctite or anything else when I reattach? The threaded mounting holes are blind, presumably; the threaded holes are not in contact with the coolant.
Any advice appreciated before I go ahead.
Oh yeah, I did test the replacement AAV though I didn't have a thermometer to hand (used measured amounts of ambient & boiling water as a rough measure. Just boiled water closed the AAV so that the air flow was reduced significantly, ie maybe to a tenth).
Keeping my fingers crossed.
1975 350SLC Astral Silver (725) / Blue (2012 - 2019.... an under-rated car)
Re: Replacing AAV.... do I need Loctite?
Post by TheMadRacoon » Thu 17 Jul, 2014 1:43 pm
Strangely, the mounting holes in the replacement AAV are a fraction too small for the screws, and I also couldn't get the original spring washers off the screws, so I'll just add the new spring washers below the originals. Can't see a problem with that.
A big thanks to Rolf and Neil at FW Graunke for drilling out the holes (straight) for me :)
