230SL indicator combination switch
W113 Roadster 1963-71 230SL, 250SL, 280SL
W121 Roadster 1955-1963 190SL
W198 Coupe 'Gullwing' and Roadster models
scorchi0
Post by scorchi0 » Mon 14 Oct, 2013 5:25 pm
Howdy all,
It seems the RHD stalks are no longer available for these cars. The LHD part is available from several aftermarket suppliers so I'm wondering if anyone knows if the LHD part will fit the RHD car?
The parts catalog only lists one part number, so I'm assuming if you order one you get a LHD part that fits all, but I'm just wondering if anyone knows this for certain.
cheers,
Trent
Image Image
Aegean
Model you own: w186
Re: 230SL indicator combination switch
Post by Aegean » Mon 14 Oct, 2013 8:28 pm
Do you have a part number ?
scorchi0
Post by scorchi0 » Mon 14 Oct, 2013 10:10 pm
001 545 55 25 is what is in EPC, so I assume is the LHD part.
Image Image
bdekretser
Model you own: w113
Post by bdekretser » Mon 14 Oct, 2013 10:58 pm
Mail support@pagode.net, they are located in Germany & supplied for my 69 280 SL with no problems in fitting
Koellner-sl-service@gmx.de
Bill
Bill de Kretser
043 435 6594
69 Mini Cooper S Mk 2
71 280 SE 3.5
82 500 SL
93 300D
09 C220 CDI
Aegean
Model you own: w186
Post by Aegean » Tue 15 Oct, 2013 8:26 am
Number I get ends 24, not 25 and appears to be the same for all markets.
scorchi0
Post by scorchi0 » Tue 15 Oct, 2013 11:32 am
That was a type, the number is indeed 001 545 55 24.
I had a response on the pagoda forums from someone who had actually fitted the LHD part without issue to a RHD car so looks like we're good to go.
Cheers for the responses folks.
Trent
Image Image
Post by John Green » Tue 15 Oct, 2013 8:44 pm
We have done it a number of times, no real drama's. from what I can figure the only real difference was the length of the lead to the plug. At one stage there was a story going around the net that you had to swap the wires for the left and right indicator to make it work, but that turned out to be an unban myth.
And, yes we can quote you on one... :dance: :dance:
Return to “W113 and W121 Roadsters & W198 300SL”
