280SE Fuel Injection
Oldgerman
Model you own: w901-905
Post by Oldgerman » Wed 18 Jan, 2006 2:49 pm
I am just about to buy a 68 280SE with fuel injection and I was after a bit of info.
The injection system looks similar to the 'mechanical' system that I think was made by Lucas and fitted to similar period Triumphs and Saabs. Is this correct? the only reference to early fuel injection systems on W108 is the D-Jetronic on the 3.5l. The engine is defintely a 6 cylinder :roll: so what system is it?
Anybody got any detailed info on its operation?
Thank you (in advance) for your help
O319-coach
Mercedes Guru/Admin
Post by O319-coach » Wed 18 Jan, 2006 4:50 pm
Bosch mechanical injection simalar to the Lucus system but far superior. Works on the same principles as diesel injection but with less importnace on the pump timing.
Very reliable so long as it is set up correctly and serviced correctly.
You must have genuine manusl to work on these cars.
Independent importer of discounted genuine Mercedes-Benz parts.
Restorer of Concours winning cars.
Sponsor of this forum.
http://www.mbspares.com.au Toll free phone 1300 787 300
Stephen
Post by Stephen » Wed 18 Jan, 2006 10:40 pm
For a starting point, check this out;
http://w108.org/forum/viewtopic.php?t=10
Stephen
Return to “W108/109”
