W108 Air con compressor bracket bolts
NZJasonT
Post by NZJasonT » Thu 19 Apr, 2018 7:52 pm
Would anyone happen to know the sizes of the three bolts, length, diameter and pitch, that hold the compressor bracket on?
I’m refitting mine and don’t have original bolts - I have some that are close but they bind and I don’t want to over tighten them, cross thread them or worse still split the housing etc
Jason
1971 W108 280se 2.8
1973 W107 450 SLC
Re: W108 Air con compressor bracket bolts
Post by Bartman4800 » Fri 27 Apr, 2018 7:36 pm
Not 100 % sure on the diameter, but it will be Metric fine.
M8 x 1 or M10 x 1.25
NZJasonT
Post by NZJasonT » Sun 29 Apr, 2018 6:19 am
Thank you Bart - I’ll try that
Jason
1971 W108 280se 2.8
1973 W107 450 SLC
ibast
Post by ibast » Fri 04 May, 2018 11:12 am
Damn, I had mine off a few months ago. I think all three are different. At least two are different. None seemed to be fine thread. The one into manifold I would guess at m8, bu the ones into the block were definitive bigger. could be m10 and m12. maybe both m10. The blind one had a big head on it, but might be just mine and hence why i'm thinking m12.
Post by Mercmad » Sun 06 May, 2018 11:24 am
It depends on the compressor model. The Harrison compressor uses SAE bolts.
Return to “W108/109”
