'66 250S back on the road
Tazzieman
Post by Tazzieman » Fri 12 May, 2017 12:18 pm
After just over a year of varied tasks , I've brought this from sad paddock to happy "plate" as it were. Auto , drives very well (notwithstanding Zenith carbs), and overall in pretty nice condition after sourcing a better interior. "Needs" a repaint , though several people have said leave it as is. Bitzer paint job! Changed steering wheel from white to black as I reckon it suits the red interior better. Aftermarket vintage alloy wheels with 7" tyres look OK; I have the "original date stamped" ones to go with the rest of this "matching numbers collectable" :toothy5:
Main task was to get it operational, iron out any subtle mechanical issues and in the future I can decide what else might need attention.
Amongst a myriad of various jobs I had to rebuild the brake system from stem to stern , and I've replaced a door , all door seals and put a new windscreen+seal in. The woodwork is 75% finished. Heater tap needs attention but hey , I'm Tasmanian and a little cold doesn't bother me. The fan works...
The car was bought new by Billy McMahon's father in law. It entered Tassy in 1982, but subsequent history is at present hazy. It's covered 120,000 miles , so just run in really!
Similar , but drives differently to my manual '67 250S.
Re: '66 250S back on the road
Post by Bartman4800 » Fri 12 May, 2017 12:23 pm
Nice car!
Heater taps are quite simple to do.
Get some 13 x 3 O-rings in 70 shore hardness (buy more than 2, they are cheap and you might cut one like me) and a tube of O-ring grease from your local seal specialist.
If you need some advice how to get them out and in, fire me a PM.
Tazzieman
Post by Tazzieman » Fri 12 May, 2017 1:41 pm
The heater problem was that the cable had broken and the arm that connects to the tap valve was missing. My donor car provided the arm (and I removed the valve just to confirm how it worked), However I have tried just about everything to see if I can move the tap in situ under the dash, but I need the longer and skinner arm option. I can't get the arm back on and it's an interference fit onto brass. So other than pulling the heater box , at this stage I am a bit stumped. I have been told a spark plug will screw into the tap valve and maybe that's how I can get the arm on.
But yes I realise the O ring is likely shot and will need replacing! Just want to have some fun with the car before going back under that dratted dash!
Thanks for the O ring size heads up btw.
VFRBoy
Post by VFRBoy » Fri 12 May, 2017 3:00 pm
Nice job! Looks great, love the colour. Mine is also 1966 250S but manual. It came over from Tassie in about 2012 with SI plates on it, now on full VIC reg and driven (almost) daily. Previous history unknown, but has had similar full brake rebuild, new windscreen. Zeniths are OK once they are balanced right.
1966 W108 250S
4-speed floorshift
Carn the Dees...
Post by Bartman4800 » Fri 12 May, 2017 3:45 pm
Tazzieman wrote:The heater problem was that the cable had broken and the arm that connects to the tap valve was missing. My donor car provided the arm (and I removed the valve just to confirm how it worked), However I have tried just about everything to see if I can move the tap in situ under the dash, but I need the longer and skinner arm option. I can't get the arm back on and it's an interference fit onto brass. So other than pulling the heater box , at this stage I am a bit stumped. I have been told a spark plug will screw into the tap valve and maybe that's how I can get the arm on.
The thread in the tap valve is M4 from memory.
Get yourself a long M4 screw, a piece of metal tube with larger ID than the valve body OD, an M4 washer and a nut.
I could pull the valve out with pliers on the M4, but if that fails you can use the screw, tube washer and nut to jack the valve out.
Most likely there is a burr on the square of the valve, that's why you cannot get your arm back on. A small file will fix your problem.
Post by T-Modell » Fri 12 May, 2017 4:12 pm
Hi, great car, looks good! Wheels are surely a matter of personal taste, but everyone should put on what he likes ... seems to be standard die Tasmania, when I see the W123 in the background with the manholes :laughing6:
Enjoy your car!
P. S.: What's that sticker on the back?
Tazzieman
Post by Tazzieman » Fri 12 May, 2017 4:53 pm
T-Modell wrote:Hi, great car, looks good! Wheels are surely a matter of personal taste, but everyone should put on what he likes ... seems to be standard die Tasmania :laughing6:
My '67 is completely standard , wheel wise!
The sticker is what remains ; Adam (ANF) put a sponsor sticker on there when he planned to use it for that rally. The boot has marks like an old table in a pub , which isn't necessarily a bad thing ;<)
Tazzieman
Post by Tazzieman » Fri 12 May, 2017 8:06 pm
Bartman4800 wrote:The thread in the tap valve is M4 from memory.
Well I had a spare moment and freed it up just now. Easier to see what's what at night with a head torch. I went through the radio hole , screwed the arm on using a spark plug. Luckily the valve was in the off position to the left ; when I cautiously tightened the plug (used a few extensions/angle socket) the arm moved fairly easily. Then I used pliers to wiggle it back , and repeated a few times and now can do it by hand.
I'll test tomorrow and the O ring may or may not be perished. We'll see! If it works I'll get another cable installed.
Hooray for the spark plug method :occasion5:
Post by Bartman4800 » Wed 17 May, 2017 5:11 pm
Or you might find it out the next time your engine gets to operating temperature and hot coolant starts pissing over your feet....
It is actually a good idea to remove the heater box. It is the only way to replace those short length hoses (hot water intake)
If they have not been replaced in the 50 years passed, it is probably due...
Tazzieman
Post by Tazzieman » Fri 19 May, 2017 11:58 am
Bartman4800 wrote:Or you might find it out the next time your engine gets to operating temperature and hot coolant starts pissing over your feet....
I've packed some towels and clean water for if the baby delivers prematurely.
Post by Mercmad » Sat 10 Jun, 2017 11:07 am
Getting a heater out of a 108 ain't easy. take the passenger seat out to get room.
Tazzieman
Post by Tazzieman » Sat 10 Jun, 2017 12:04 pm
Mercmad wrote:Getting a heater out of a 108 ain't easy. take the passenger seat out to get room.
I pulled one from a donor car without aircon , which made it a touch easier.
Neither of my 108s have aircon now. A major advantage in living in Tas! I found the general ventilation more than adequate , but obviously you wouldn't want to be stuck in traffic on a hot day. Luckily , that isn't a problem here.
Return to “W108/109”
