Hand Brake Return
dreadnought
Hand Brake Return
Post by dreadnought » Sun 03 Mar, 2019 5:44 pm
Is there a spring that returns the handbrake to the dash when the handbrake is disengaged, my handbrake does not return it just slides so I push it back in, it slides very easily, any help much appreciated. 1988 SE 300.
Re: Hand Brake Return
Post by CraigB » Sun 03 Mar, 2019 6:01 pm
I think so. If you pull off the side kick panel under the dash on drivers side the mechanism is visible. Is it adjusted and works otherwise?
dreadnought
Post by dreadnought » Sun 03 Mar, 2019 7:27 pm
The handbrake appears to work fine, I just picked the car today, is there anywhere I can download a manual for a 300SE or a parts fiche, regards
Post by T-Modell » Sun 03 Mar, 2019 7:37 pm
Hi nameless ;-)
this is a picture of a W115, but I'm pretty sure the W126 is similar (at least the R107 is). You see the spring and the mechanism. The whole stuff is fixed at the dashboard cross bar and - probably with the W126 as well - two screws in the firewall, which can be seen inside the left wheel arch.
dreadnought
Post by dreadnought » Mon 04 Mar, 2019 11:01 am
T^hanks for the Pic and info Thomas, I will have a look, regards Maurie.
dreadnought
Post by dreadnought » Wed 06 Mar, 2019 6:26 am
Thomas, I probably should have mentioned my vehicle is right hand drive, to All, is a parts fiche in pdf form available anywhere as a download, regards Maurie.
gjm
Post by gjm » Mon 18 Mar, 2019 6:27 pm
Is there a guide for handbrake adjustment? Our 500SE handbrake does work, but it can take several attempts to release it sufficiently to have the dash warning light go out.
1991 W201 2.6/3.0 auto, Willow Green metallic
1989 W126 500SE, Piano Black
