Battery warning light 1987 4210sel
Davgolla
Post by Davgolla » Mon 22 Jan, 2018 5:21 pm
Hi all...Knowledge /guidance requested.....battery warning light stays on at idle. Goes out as accelerate and at usual cruising speeds. Fairly new/full strength battery( 3.5 years old).
Re: Battery warning light 1987 4210sel
Post by Ivanerrol » Mon 22 Jan, 2018 6:19 pm
Consensus would be that your alternator regulator is near kaputt.
It's an easy change - back of the alternator.
If you have a multi-meter then measure the voltage across your battery at idle. Should be over 14 volts.
Ring the forum sponsor - MB spares to get a new one - they are cheap.
it's an easy DIYer.
here is the video : https://www.youtube.com/watch?v=NhAAIY5TLLI
The brushes on the regulator wear down with age.
